oscaac
About oscaac
  • Birthday 06/25/1981
    Austin, TX, US
    2005 Porsche Carrera
    2014 Cayenne
    2018 Ducati 959 Corse
1,166 profile views
oscaac's Achievements
  1. I normally use 10-15 psi. Pumped in 10, walked away for a few minutes, came back and it was at 5. After taking off all the plastic covers, I can see the fluid slowly leak out when I slightly move the reservoir (without the power bleeder attached).
  2. Hey All, So I noticed a leak between the master cylinder and brake fluid reservoir on my 05 997 Carrera. I was doing a brake fluid flush which I've done a few times using a Motive power bleeder and noticed the pressure started falling even before I opened the brake caliper nipple. I finally found some brake fluid oozing out between the seals of the master cylinder and reservoir. Given the 911 is 15+ years old now, I expect this is normal. Questions: what do I need to replace here? The seals seem to be part of the master cylinder so I assume I need to replace it? Should I replace the brake fluid reservoir as well? Thanks in advance. -Oscar
  3. I noticed some water on the back of my 911 (2005 997 Carrera) this afternoon. Looking under the car, found it was coming from the front, behind the driver-side tire. Looks like the windshield washer tank is leaking? Considering the car's age and that I've never had to replace it before, I assume that's it. Anyone know how hard to replace the tank is?
  4. I noticed an issue with my Cayenne base 2014 V6 958: when in park, it idled up and down to 1500 rpms and normal. It only happened once then the next day, the CEL came on. I codes were System too lead at idle Bank 1 and 2 (P218700, P218900). I researched the issue and found that similar situations could be caused by fault air oil separator. I tried to find the location for the AOS but found one thread on Rennlist that there is no AOS on the Cayenne V6. At this point, I could not find any leaks in any of the hoses so I took it to a independent shop. Well, I just heard back from them saying the issue is with the AOS and it's a $400 part. So question is, does the V6 958 have an AOS. If not, what is this $400 part they're going to replace.
  5. Hi All, CEL came on this past Saturday while I was out of town on my 2014 Cayenne base. It was running fine so I drove back yesterday and checked the faults with my Durametric but it's really strange. The software is saying no current faults. I disconnected and turned on the Cayenne but the light is still on. I turned it off, re-connected and it still said no current faults. I then erased all fault codes and restarted. CEL is on. Anyone ever had this situation before? Seems like my CEL is stuck on with no faults...
  6. Thanks all. So it I took it to an Indy shop and the first thing they noticed was one of the coils had rust. Not sure if the previous owner/dealership pressure washed the engine before I got it but I guess I need to replace all the spark plugs and coils anyway.
  7. Hi All, So today, after putting gas (Shell, premium) in my 2014 Cayenne base, I got on the freeway and shortly after, the check engine light came on and Cayenne started shaking abnormally. I was able to turn around and get back home but I noticed 1. When I stop, the CEL flashes and the Cayenne shakes a lot more 2. When I press on the gas, it takes a long time to pick up speed (really struggling). I connected the Durametric when I got home and I see the following misfire fault codes on it. Anyone have any suggestions? Cayenne has around 62k miles on it. P030000 Random/Multiple Cylinder Misfire Detected Factory Fault Code 10203 Warning Indicator Off Test Not Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cycle Fault Active P030100 Cyl.1 Misfire Detected Factory Fault Code 10591 Warning Indicator Off Test Not Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cycle Fault Active P030300 Cyl.3 Misfire Detected Factory Fault Code 10593 Warning Indicator Off Test Not Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cycle Fault Active P030600 Cyl.6 Misfire Detected Factory Fault Code 10596 Warning Indicator Off Test Not Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cycle Fault Active P030200 Cyl.2 Misfire Detected Factory Fault Code 10592 Warning Indicator Off Test Not Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cyclea Fault Active P130A00 Hide cylinder Factory Fault Code 10205 Warning Indicator Off Test Completed This Monitoring Cycle Test Failed Since Last Clear Test Completed Since Last Clear Pending DTC Test Not Failed This Operation Cycle Fault Passive
  8. Thanks wwilliams88. I did some searching and found some issues with the older versions but nothing major for the newer V6 models. Finding they tend to be very reliable as long as you keep up with the regular maintenance. Thanks again. I'm really looking forward to adding a new Porsche to the family.
  9. Hi All, I'm looking into buying a 2014 Cayenne base. I found one here in Austin with 60k miles. I looked at the service manual and it doesn't seem like there are any major service jobs needed so far. I'm planning to get a PPI on it before we make the deal. Question is: are there any known issues or things I need to be aware of before I make the purchase? I know when I got my 997 911, the water pump went out, the coolant tank started leaking...all known issues for the year and age of the car. Any info would be greatly appreciated. Thanks.
  10. Thanks Mijostyn. However, the upper part of the bleeder screw is not broken off completely...yet. The top part is just rounded off so my 11 mm wrench doesn't catch it. I was thinking of using a damaged nut remover to try to take it off and replace it. If that doesn't work and breaks the top part off, then I'll use your advice with the Easy Out. Thanks for the tip on the CorrosionX. I'll start doing that too to prevent this from happening again.
