Nick_USA
Everything posted by Nick_USA
  1. Loren, I want to get my dealer to do the switch from Fahrenhuit to Celsius on the AC/Heater control. Can you please provide instruction for the PST2 process. He didn't know how to do it. I have an 03 Boxster S. Thx Have you tried this? Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays. Loren, I have also tried this method with no success (2004 Boxster S) so if you know the PST or PIWIS sequence that would be great. Thanks in advance.
  2. OBC enabling.... I see the guys are planning the OBC enable in a future release... but does anyone know if this is soon?
  3. Thanks and I see the TSB, do you know how much an OPC is likely to charge for the work? I saw in a previous discusion there are two type of switch, the TSB mentions one, but can you confirm the part number for the LHD switch?
  4. Is the sports exhaust system, the wiring harness and switch still available for a 2004 (LHD) Boxster S? If so what are: 1. The Part Numbers? 2. The cost of the parts? 3. The cost of fitting?
  5. Bridge the microswitch with a wire to prove this. Also do the windows return to the up position when you re-latch the roof (ie drop them manually, then open roof, close roof and then re-latch), if the windows do not raise the microswitch is the problem for sure.
  6. ...not sure about the front spoiler.... but would be good if you can just order the rear 'pop up' one
  7. How did the trial go ?
  8. and the guide price is? ......$122,900 for the base model
  9. Thanks also
  10. I have noticed on several occasions that my keys fail to operate the central locking. Further to that the light on the key stays on. The only way to solve this is to take the key apart and remove the battery for 5 minutes then re-assemble it. I have also tried new batteries..... Any clues on this one? Has anyone else suffered this too? The only thing I can think of is static discharge affecting the remote.....
  11. 986 504 986 00 "clip" Thanks
  12. What is the part number for the 'Red Clip' that enables the internal alarm sensors when the roof is down?
  13. I have tried the method you suggested on several occasions. I have not tried the PST2. I am on the East Coast near Greenwich, some way away from the SF area.
  14. I having tried on various message boards (with no sucess) to find out if it is possible to switch between degrees F and degrees C. I have had many people suggest the temp re-circ and the + key but this doesn't work on a 2004 Boxster S. Is it possible to do this using the PST2, if so what is the method?
  15. ....and the part number is???????
  16. Is there a part number for just the half of the key with the rubber switches in it as these seem to wear out or split over time and not the whole key?
  17. There is a bag you may find it (as I did) hidden in the pocket in the front of the spare wheel cover. Nick
  18. Having managed to get the OPC to enable the OBC is it possible to get them to and the stalks if so is there a TSB or Worksheet for them to do this and how much is it likely to cost?
  19. I have a 2004 USA Boxster S and I am wondering if it is possible to carry out the OBC upgrade on a 2004 model? If so is it still possible to enable the OBC at the dealer on this model? Nick
