leonidasb22
About leonidasb22
    CT, USA
    2004 911 Carrera c2 manual
1,497 profile views
leonidasb22's Achievements
  1. Yes! That was the issue. Sorry for the late reply.
  2. logray, I'm thinking of the B16 (PSS10's). What you say "the stock suspension was much more compliant than the PSS10's" can you elaborate on the ride of the PSS10's. Also, how much did you lower them? And what number setting did you choose? Did you change any other factory OE suspension parts to aftermarket like bushings or mounts? I'm trying to decide between PSS10 or RoW Springs and B8's.
  3. Hi Porsche community, I've read and narrowed down a suspension upgrade for my 2004 Porsche 911, C2, Coupe, Manual 6 speed. (I currently have the standard suspension.) Bilstein B16 (PSS10) 48-186322 vs Bilstein B8's with RoW M030 springs. RoW M030 springs - (These will lower my USA vehicle 20mm(.78") in Front and 10mm(~.39") in the rear. This would be a great height for street driving in USA. The roads are horrible in the USA. This will give me a better look, stiffer springs, and a little rake. And the Bilstein B8's will also firm things up bit more. Bilstein recommends B4 or B8 for the RoW M030 springs. I'm leaning toward the Bilstein B8's(over the Bilstein B4's) to improve handling. I'm hoping it wont be too aggressive and still street-able but I think it will be a good because I'm going with a Porsche European Spring. Has anyone used Bilstein B8's with RoW M030 springs? How do they perform on the street? The other option is the Bilstein B16 (PSS10) 48-186322. The highest spring setting on this also matches the RoW M030 springs. Which will lower the my vehicle 20mm(.78") in Front and 10mm(~.39") in the rear. This is my current target setting, since Porsche recommends this and is a good balance of what I'm trying to achieve without bottoming out and scraping. Of course they can go lower but that's not my target. They also have adjustable dampening settings to dial the bump and rebound. I am primarily a spirited street driver who appreciates precise steering and handling. This is my focus. Between these two kits what does the Porsche community recommend? Looking from a place from experience in comparing these. Right now —all in all there's also a cost difference of about $1,200, when you factor in strut bearings, strut mounts, spring pads, misc. etc. And the other issue with is the RoW M030 springs have to come from Europe and may take many weeks as there's delays (due to Covid). I'm getting quotes of up to 6 weeks. I'd love to get your input. Thanks in advance all.
  4. JFP. I have decided that I will just swap out the starter with a brand new one. I just want a faster fix and I'm hoping a new one will outlast— rebuilding this one. I appreciate your help on this issue and help diagnosing the sound. Would you like me to send you my current starter for a spare? Its all clean, and worked perfect(except for the Bendix gear getting stuck sometimes— hence the reason for all this). Now that it is clean, you will have to grease it up. It seems that it was already replaced, as its BOSCH manufacture date is 2012. I also had to drill out the heads of the 3 torx M5 bolts so those would need to be sourced for a good rebuild. Let me know, and I'll put it in the mail since you helped guide me along the way and I was able to learn about this. Thank you.
  5. JFP I have removed, disassembled, and cleaned the entire starter internally. Tomorrow I would like to grease and assemble it. The small internal gears appeared to have a thick grease on them. Is the DuPont Teflon Non-Stick Dry-Film Lubricant you recommended for all the internal gears? Or just the shaft of the starter gear which is more exposed to the clutch? Which lube do you recommend for the small internal gears and the Bendix drive gear? Also the DuPont dry Teflon spray is out of stock and I can't get my hands on it until next week. These are alternatives that I have found in stock. Are you familiar and do you recommend any of these to the DuPont dry Teflon spray or any others? Blaster Industrial Graphite DRY Lubricant (not teflon) Blaster Advanced Dry Lube with Teflon WD-40 SPECIALIST Dry Lube with PTFE (teflon) Thanks again. You've been right all along so far.
  6. JFP Thank you very much for your fast response! Would you recommend "cleaning and relubricating the drive" or just replacing the starter with a rebuilt Porsche/ or OE new unit for about $275? When this occurs does it signal that other parts in the starter are on their way out and will fail soon even if I was to "clean and relubricating the Bendix drive"? How hard is it to "clean the drive and relubricating it" vs just replacing it myself? Thank you again.
  7. Hi Porsche Community, I need some help to diagnosis what this grinding noise is —— immediately after startup. The grinding noise lasts about 1-2 seconds and only happens on startup. It goes away after. It doesn't happen on every startup. It occurs about 1 out of 3 starts. Sometimes it happens on the first start. Sometimes it doesn't. I started the engine consecutively 3 times and it happened on the third start. I included a file called "good start audio" clip and a "grinding startup noise audio" so that you can focus on the grinding noise and only the difference in the sounds. It starts up right away, no problems or hesitation. No error codes. Taken well care of. 2004 Porsche 911 Carrera 2 (996) - RWD 6 Speed manual 78,000 miles Thanks in advance. Good Start Audio.m4a Grinding Startup Noise Audio.m4a
  8. I bought a heavy duty large c-clamp and tried it. It didn’t work on my bolts. I then went to a machine shop and they heated and hammered them out for $20. Thanks everyone for your support on this issue. I'm so glad I got this resolved quickly.
  9. Wow okay RFM. Thanks for the info. Seems like you removed these bolts before. Is a hydraulic press easier or the torch and hammer is the preferred method? I may try to find a machine shop that would do it for me if the torch method is still difficult. Do you think a big steel C clamp could do the trick, without torching?
  10. The replacement Porsche bolts now have a hex head.
  11. My catalytic converter bolts are in bad shape and I want to replace them. These bolts seemed to be welded onto the cat. Have any of you ever removed these? Do you know how I will get these off without damaging the cat?
  12. Manual Transmission Oil Change Instructions By Loren How to change your manual transmission oil Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. Parts you will need: 3-4 liters 999 917 546 00 (Shell) Shell Transaxle (75W-90) or Mobil Mobilube PTX (75W-90) Approved Manual Transmission Oils 000 043 204 20 Mobil (Mobilube PTX) - 20 liter container 000 043 204 19 Shell (Transaxle) - 20 liter container 999 917 546 00 Shell (Transaxle) - 1 liter container Note: All are synthetic GL4 and GL5 rated (or "non-conventional processing") oils. GL oils have good light running properties because of their light low-temperature viscosity as well as a high level of temperature stability. Hi Porsche community, Here's an update on the transmission oil for the US market. Shell Transaxle Oil 75W-90 is now called Shell Spirax S5 ATE 75W-90. Fluid Part number 999 917 546 00 has been updated to 000 043 305 49 Now I have 2 questions for you all regarding Manual Transmission Fluid / Rear Differential Fluid for my manual 2004 996 Carrera 2 It seems that the 1 Liter Porsche container 999 917 546 00 is the Shell Product in the USA. Suncoast Porsche sells both the Porsche oil (which should now be the Shell Spirax S5 ATE 75W-90) and the Mobil Mobil Mobilube PTX(75W-90) which is originally intended for European markets. They are roughly the same cost. 1. Is the Mobil Mobilube PTX(75W-90) preferred and superior over the Shell(75W-90) Porsche part # 999 917 546 00? 2. When I called Suncoast Porsche they said that Mobil 1 Delvac 75W-90 and Mobil Mobilube PTX (75W-90) should be almost the same. But when searching through many 996 transmission fluid forums, it seems that Mobil 1 Delvac(75W-90) is better for track use and the Mobil Mobilube PTX (75W-90)/or Shell(75w90) is better for shifting when gearbox is cold. Since I don't track my car, I am leaning toward this fluid for extra protection during cold starts. Now I would need 2.7 liters for the Transmission/Rear Differential. I could buy 3 liters of Mobil Mobilube PTX(75W-90) or the Porsche 999 917 546 00 Shell(75W-90) for a total of $120 + tax and shipping. Or I could buy the Mobil 1 Delvac(75W-90) which is sold in 1 gallon for $55. Money wise Delvac wins. But the main thing is I want to put the best product in for the vehicle and my usage, money aside. Loren and others, how do you feel about Mobil 1 Delvac (75W-90) for street use on my G96/01 transmission? My gut always tells me to stick with Porsche part 999 917 546 00(Shell) or maybe the Mobil Mobil Mobilube PTX(75W-90). I would like to here the Porsche communities arguments for and against. Best Regards, Leonidas
