white out
Everything posted by white out
  1. Anyway you can get video the noise?
  2. Based upon the pictures, that should fit a standard car since it's the same muffler design; 996GT3 and 996 narrow body use the same rear bumper. Racer S, keep us updated with the results, it looks like a quality piece that isn't commonly used.
  3. You're arguing your hypothetical. I actually did the swap. But yeah, keep arguing your point. :cheers:
  4. Again, your pricing is waaay off. I spent nowhere near $10k on the build and my M96 didn't sell anywhere near $10k. Like I said, the M96 covered the costs. I didn't charge myself an hourly rate, which is the most expensive part of the swap if you have someone else do it. If you can't find a shop at $150/hr, then don't expect to spend that much on the swap. :thumbup:
  5. You two are really missing the point. If you go to an expensive shop, where you're paying $150+/hr for labor, and depending on which LSx motor purchased; the swap could cost $20k. If you do the swap in your garage with a used engine, the swap will be significantly less money. My swap was covered by the sale of my car's M96, which sold within the average price range JFP stated earlier in the thread. Here's a breakdown of the costs: Renegade kit: $4000 LSx longblock with accessories: $100-$10,000 Wiring kit: $500 Misc: $500 Depending on how you play it, the n/a 996 can get an additional 50hp and 100ft-lbs of torque for no additional cost by swapping to an LSx. The LSx responds well to aftermarket cams, n2o and boost; the 996 has lots of room for turbos with the LSx swap. So depending on what power levels are wanted, the LSx can compete with the same power output as the 996TT for a fraction of the cost per hp. Also, you guys think a '99 c2 with 128k miles sells for $20k in stock form? :lol:
  6. If you paid a top dollar shop to do the swap, the labor charges can add up. In my specific case, the swap cost was covered by the sale of my M96. It's really not that hard to wrap your head around.
  7. Look above, the sale of the M96 covered my swap.
  8. I paid for my swap with the sale of the M96.
  9. Not at all, but you are vastly over estimating what a replacement M96 can cost. My comment was based on your $4,000-$7,000 figure. Three pages into the post and you still seem to have trouble focusing. Whether he was joking or not, white out was talking about putting an LS engine into a 996. The purists I was referring to are the ones that would think it sacrilegious stuffing a Chevy engine into a Porsche. Talk about missing the point. Anyway, there are only a few hours left in the year. Maybe you'll learn to not let things bother you too much in '15. Happy New Year, all! :D Being "sacrilegious" never entered into the conversation. The LS swap is an expensive proposition that typically ends up both reducing the resale value of the car as well as dramatically shrinking the pool of potential buyers for the car; all of which is purely economic rather than religious in nature. I sold my LS swapped '99 996C2 coupe with 128k miles for $25,000 in 2013. While the swap dramatically shrunk the pool of potential buyers, it did get coverage on a national TV network, tens of thousands of views online, and sold in about a month. http://996ls1.blogspot.com/
  10. I think you underestimate how cheap an LSx and PCM can be found for. Biggest cost is the KEP engine/trans adaptor and engine mount (renegade if you buy it).
  11. I posted jokingly. But for an M96 replacement, the LS swap is a good option. Depending on how you go at it the swap can cost the same as a replacement M96 or $20k.
  12. It worked! Thank you!
  13. Thanks! I'll give it a shot tonight
  14. First off, whomever designed the locks on the Frunk/Engine cover for the '99 cars has a special place in hell reserved for him. Second, I spent an hour last night trying to find the front release cable through the right blinker. That was USELESS. So using my superior skills of trying to figure out how to open a very basic trunk. I decided to look at the source, the latch, from under the car. Here's my method for opening the trunk. My car does not have the 3rd radiator, but it has the cut outs on the bottom of the bumper cover. It is real tight, but you can wedge your head under the bumper cover and look through the radiator cut outs and see the cable running along the bumper beam. Use a coat hanger, reach up through the cut outs and pull the release cable down. Once the frunk was open I placed the cable in the bumper supports so that in the future I can reach under the car (ie not crawl under) and pull the cable. SPECIAL NOTE - careful with your head, it is a tight fit under the front of the car. I gave myself a black eye from wedging my head under the car. :lol: yes, my bumper cover is in bad shape - previous owner street parked it in Chicago and liked to tailgate.
  15. That's not a bad idea. But how do you plan on getting the jack under the car?
  16. I have a 220: 4462 15062592 Any chance of getting a code?
  17. Check the bushings in the swaybar mounts.
  18. None of the information you just posted suggests that the system cannot be burped the traditional way. The coolant fill tank/expansion tank is the highest point of the coolant system. Under pressure air goes up, in the 996 it will end up in the coolant fill tank/expansion tank. The pressure created by the cooling system bleeds the cooling system of air. Basic physics is generally impossible to change.
  19. I understand that the 996 has weak cylinder walls, but the engine shouldn't get hot enough burping the system to score or crack a cylinder. The coolant tank is the highest part of the coolant system, how wouldn't air get out after properly burping the system?
  20. What's wrong with burping the coolant system the "old fashion" way?
  21. I have a set available. They basically pull the rear (narrow-band) o2 out of the exhaust flow. I run the same simulator's on my Lambo. Nick
  22. for the front, check sway bar mounts. Nick
