formulamd
About formulamd
    Chicago
    2005 Porsche Cayenne Turbo
    2001 Pontiac Trans Am WS6
    Volvo S60R
    Audi A4 3.0
    Lexus ES300
    Dodge Daytona Shelby
380 profile views
formulamd's Achievements
  1. Anybody have any ideas or seen anything like this? I am getting inconsistent current measurements. If i pull the radio and the Kessy fuse i never approach the 2+ amps randomly. Can it be that both modules are bad? Or is the kessy talking to the radio via false CAN messages.
  2. Update, with the radio fuse pulled, I still get a 2 A peak, therefore my assumptions are that the radio is being woken up. I pulled the KESSY module fuse, of which my current is back where it should be 100-200mA (at least over night). I have read that the KESSY module can cause all sorts of ruckus. Would it be safe to say that this is the issue? Also will I have to relearn my keys if I try to repair the module? Any input would be greatly appreciated.
  3. I got the logger running as the car is sleeping. I pulled the wiper fuse and still have the battery drain condition. The condition seems to be where the drain will draw a constant 5-7 amps for approximately 5-10 mins then return to 150mA. I hear my radio cd mech and navi dvd running. I pulled the radio fuse and so far i have not seen this current draw. Has anyone seen the radio act this way? I notice that my navigation and map will not get past the splash screen of one bar.
  4. Ok thanks! I will try pulling that and see if the battery drains. I also am going borrow a data logger with a current shunt and let that run overnight to see the current draw over time.
  5. Quick update, With the car in "sleep" About every 10 min, I notice the wipers move a bit. Has anyonce seen these haunting issues haha?
  6. Hi All, I wanted to thank everyone for all the DIY's and other information on this forum. Its been a BIG help! Anyhow, I have a 2005 Cayenne Turbo which has an electrical issue that will not seem to go away. This issue recently is the battery has been draining intermittently to the point where i let the car sit overnight (10-12 hours) and the battery voltage will go down to 7-8VDC. Other days, I let the car sit for a few days and starts up right away. What I have done/ recorded. I have no Durametric codes when this happens, other than the VBAT low threshold on every module which goes away upon charging the battery and resetting the "module codes" I replaced the battery, one with OEM and bought another one from autozone as a backup, both check out ok. and have been load tested multiple times. (Side note, I do not have the 2nd battery in the trunk) I will get a battery/generator warning every once in a while upon starting which does go away. I have been logging my battery voltage with the durametric and with a DVM in the cig lighter. When this error happens it seems like the alternator is not charging ( 11.2-11.5VDC) When the warning goes away, my voltage goes to 14.2-14.5VDC and stays there constantly. Upon loads, i.e headlights, radio brake lights etc it drops to 13.8-13.9VDC. This is telling me that my alternator is working and charging the battery. I did some resistance checks around the v+ battery terminals and cleaned up what was though as a "higher resistance" on the + cable of about 1 ohm. I cleaned the contacts and put star washers on every screw terminal which fixed this issue. While the battery cable was out, I measured paresitic current draw with the car in "rest/sleep" mode and i only drew 100-150 mA. One thing i notice is when the car is sitting, in rest. I do hear things under the hood along with my radio cd mechanisim every once in a while move. I know for a fact i am not drawing this current but it will settle down and go quite which will then draw 100-150mA Sorry for the long winded start of a thread, I am slowly giving up on what could be a matter with this truck and am hoping any of you could point me in a right direction on this issue. Thanks
