Uwon
Everything posted by Uwon
  1. Several years ago I installed a LN Engineering oil filter adapter in my '06 C2S largely because of the hype created on this and other forums surrounding the IMSB issues. (I also removed the IMS seal and adopted the 5k oil change practice, amongst other things). Notwithstanding, I always wondered how this small canister filter could be better than Porsche's own cartridge version. So today I had my first chance to use my new sniffy oil filter cutter (amazon.com) on an accumulated collection of used oil filters from the car... The more oil filters I cut open and examined for metal particles (fortunately none found), the more I questioned the use of a filter with such small filtering area. And, quite frankly, I see little difference in the filter paper material used in the recommended NAPA Gold filter and the Porsche cartridge.... My layman' reasoning concludes that it's easier to push he same amount of oil thru the larger Porsche cartridge filter, and, certainly the filter would be cleaning inch for inch through the same cycle. So, is the oil filter adapter gizmo all hype? Thoughts? Cheers, Johan ​
  2. Check coils for cracks. Plugs probably still OK. Clean intake. Change Water pump, AOS, belt, and idler wheels. Cheers, Johan
  3. '06 C2S. Just replaced my "4 narrow electrode" factory installed Bosch plugs with the equivelant "2 wide electrode" NKG. Is there any difference in performance and life? Thanks in advance. Cheers, Johan
  4. Pulled out my old ohm meter which turned out to be more accurate.than the new one. Coils read .4 and it made little difference in readings after being in the fridge for an hour and freezer an hour after that. Thanks for your help, Loren. Cheers, Johan
  5. OK, got the high powered magnifying glass and found the 1 and 15 labels. Any thoughts on the ohm readings at 24 degrees? On second thought, I'll put one in the fridge and report. Johan
  6. Hmm..... I presume that terminals 1 and 15 are the outer pins in the three prong plug receptacle. Right? All my coils measure .1-.2 ohms at about 24 degrees Celsius. Don't know what the effect is as a result of the temperature change. Also, my ohm meter may have a slight permanent offset. Thought? Thanks in advance. Johan
  7. Just changing the spark plugs on my '06 C2S so I thought that I should also check the resistance on the coils which are only 3 years old with about 30K miles. Searched the forum but can't find any info on the acceptable range. The Bentley manual does not have any info either. Would appreciate help on this. Thanks in advance. Cheers, Johan
  8. ^^^Yes, you are spot on! Not much elevation difference between the IMSB and the shallow sump. Just reinforces that the oil level should always be right up to the top (one bar down is not acceptable to me) as extra insurance. And 5w40 of course. Johan
  9. With reference to oil getting at the larger non-removable IMSB, see post #48 in http://www.renntech.org/forums/topic/43715-clutch-aos-water-pump-thermostat-diy-questions/page-3?hl=uwon Hope this helps. Johan
  10. How long after the valve job were the valves re-adjusted? Johan
  11. Never heard if it before but I now understand the issue. Sounds like the wear is associated at least in part to the number of times the clutch is depressed. Interesting that in that I drove my 3.4 turbo converted Carrera over 250K miles including about 10-15 track days per year over a 13 year span, and I replaced the complete clutch once and only re-faced the disk a couple of times. Always enjoy reading your valued analysis and advise. Cheers, Johan
  12. JFP, thanks for your reply. I have experienced slippage and significant change in pedal travel with my other cars but never a harder pedal. Out of interest, would you be able to explain why the pedal gets harder as the clutch approaches its end of life. Thanks in advance. Johan
  13. JFP, car has 75k highway only miles, hardly any city driving, never tracked. Johan
  14. '06 C2S. Just flushed/bled brakes and clutch. Clutch pedal still engages at about. 2" from the floor. Is it on the way out? Thanks in advance. Cheers, Johan
  15. Had a similar issue finding the right plug with my C2S but I don't know if the transaxle is the same as your C4S. Perhaps this thread may help, starting at post #80 http://www.renntech.org/forums/topic/43715-clutch-aos-water-pump-thermostat-diy-questions/page-3?hl=uwon Good luck. Johan
  16. Here is the actual link referred to above.. http://www.renntech.org/forums/topic/44731-transmission-half-shaft-leak/?hl=uwon#entry241655 Don't forget to check the trani oil level while the panels are off. Good luck. Johan
  17. J- as you can see, there is great ongoing support. I tackled the clutch issue a couple of years ago and it was through this forum, no- that should read, because of the dedicated enthusiasts on this forum that I was able to successfully tackle the clutch issue in my garage. Just read the continuous ( and almost instant) guidance that I received from members such as loren, JfP and logray. http://www.renntech.org/forums/topic/43715-clutch-aos-water-pump-thermostat-diy-questions/#entry234912 Cheers, Johan
  18. Please note that the 3.6 and 3.8 have different parts numbers. The Carrera S is cheaper than the 3.6 at Pelican. Go figure. Johan
  19. +1, been there-exactly same symptoms and solution. Johan
  20. RPM, are you saying that the 997.1 C2S has a different clutch than a "standard" C2? If so, is it still a dual mass type that cannot be resurfaced? j - 78,000 miles on my '06 C2S still going with the original clutch. Cheers, Johan
  21. Been there done that. You will need the household hairdryer, a milk crate to sit on and lots and lots of patience. Takle small areas one at a time. Gently heat the film and pick an edge, pull slowly, yes slowly, so the film does not rip ( or worse pull the paint off). It took me over three hours with lots of breaks to stretch those limbs to remove the stone guards and front end. I also raised the sides and front end to get to the lower portions. You will probably also need a clay/polish job to blend in the old and new. I had a slight impression left on the trunk from the top edge of the film so I made sure that the replacement film followed exactly the same line. Hope this helps. Johan
  22. I have the same issue with my 997-1. Told by the dealer it can't be turned off so you have to turn down the radio volume every time you start the car. What a pain! Johan
  23. Not my cup of tea. Disturbs the flowing lines.M2CW. Johan
  24. Just an observation that if you are tracking your car you MUST use heat resistant paint and clearcoat to prevent discoloration and imminent blistering from heat such as VHT. Johan
