toddmac12
Everything posted by toddmac12
  1. Both small half moons on either side face the valve cover.
  2. TDC for a given bank will have a larger "half-moon" on the crankcase side and smaller on the valve cover side.
  3. You will not be able to turn the rear wheels with the parking brake on. The drive shaft should rotate when you rotate your rear wheels.
  4. Did you try turning the rear wheels?
  5. LOL, you are right sorry for the mistake. The door lock mechanism was another repair I had to make. I was able to get my window regulator rebuilt for $180 from a service listed on eBay.
  6. I bought a used one on EBay in 2017 for $70. No problems so far.
  7. Check for vacuum leaks. Sent from my Pixel 2 XL using Tapatalk
  8. Where did you get them? Sent from my Pixel 2 XL using Tapatalk
  9. I bought the tool for $140 on Amazon. It's called Hub grappler puller. You will also have to get a hub puller set which sells around $100. It will more then pay for itself because the dealer or auto shop will charge you much more. Sent from my Pixel 2 XL using Tapatalk
  10. Check this out. Check the video out at 22:50 for the tool that is used to remove and install the bearings . Sent from my Pixel 2 XL using Tapatalk
  11. See photo where Reed switch is attached to vent valve. Sent from my Pixel 2 XL using Tapatalk
  12. See attachment photo Sent from my Pixel 2 XL using Tapatalk
  13. It is attached to the side of the vent valve. Sent from my Pixel 2 XL using Tapatalk
  14. Check to see if the Reed switch is in place. It is a sensor that is activated when a gas station fuel pump nozzle is inserted in the filler neck. Sent from my Pixel 2 XL using Tapatalk
  15. I was able to find one on eBay. Sent from my Pixel XL using Tapatalk
  16. The micro switches that control the door drop are connected to the door lock actuator. I was able to find a used actuator for $60.
  17. I had the same problem with my window. I tried replacing the micro switch, but I finally fixed it by replacing the door lock actuator. I found a good used part. No more problems. Sent from my Pixel XL using Tapatalk
