MomentumGuy
About MomentumGuy
Contact Methods
  • MSN
    dsullinger@mindspring.com
  • Website URL
    http://www.donsullinger.com
  • Yahoo
    don_sullinger
    Atlanta, GA
    1986 Porsche 944 (NA)
    2006 Porsche Cayenne S
    2000 Audi A6
    2004 Audi S4
1,048 profile views
MomentumGuy's Achievements
  1. Valentine One Hardwire to Homelink The following procedure was used to hard wire a Valentine 1 detector into my 2006 Cayenne using the Homelink as the power source. Hardware: T-20 Torx head screwdriver (magnetic recommended) T-25 Torx head screwdriver Needlenose Pliers Flat Blade Screwdriver Pocket Knife Electrical Tape Hardwire kit from V1 Multimeter (recommended) Procedure Remove roof console Start by removing the two screws behind the sunglass holder with the T-20 Torx screwdriver: Next, remove the lens over the Author MomentumGuy Category Cayenne (9PA, 9PA1) - Mods Submitted 12/04/2005 09:45 AM
  2. The following procedure was used to hard wire a Valentine 1 detector into my 2006 Cayenne using the Homelink as the power source. Hardware: T-20 Torx head screwdriver (magnetic recommended) T-25 Torx head screwdriver Needlenose Pliers Flat Blade Screwdriver Pocket Knife Electrical Tape Hardwire kit from V1 Multimeter (recommended) Procedure Remove roof console Start by removing the two screws behind the sunglass holder with the T-20 Torx screwdriver: Next, remove the lens over the lights on the front of the console (I was able to pry this out with my fingernails, if you are not so equipped, I recommend a flat blade screwdriver wrapped in electrical tape) There are two more T-20 screws that need to be removed: Locate and tap into the Homelink power source There are three wires leading into the Homelink module – two red wires and one brown wire. At this point it is recommended to test these wires with a voltmeter/multimeter to make sure you are about to tap into the correct wire. Using a pocket knife (scissors on a Swiss Army knife works best), remove the tape holding the wires together so you can get enough room for the V1 wiring harness connector: Position the V1 wiring harness connector around the selected wire and squeeze closed using the needlenose pliers. Wire power adapter Plug the red wire from the power adapter (with the RJ-11 phone jack) into the harness connector. Next, using a T-25 screwdriver, loosen the screw holding the sunroof module to the frame enough to get the blades from the black wire of the power adapter under the screw head. Re-tighten the screw to ground the power adapter. If this is not available, you will need to test for a suitable ground screw using a voltmeter/multimeter. Plug in and test Plug the provided phone cord into the power adapter, and feed the other end of the cable through the space between the headliner and the windshield. Be sure to feed enough cord to reach your chosen detector location. Plug in the detector and turn the ignition key to “on.” If the detector is on, it should go through the power-up test. Turning the key off with the detector powered on should turn off the detector. Completing installation After successfully testing the detector operation, attach the power adapter to the vehicle using the Velcro/adhesive on the adapter and placing any extra cord under the headliner, out of the way. Put the roof console back, but do not replace the screws until one last test of all the switches and detector operation has been performed. Once everything has been checked, replace the T-20 screws and the lens over the console lights. Here is the finished installation:
  3. I've had my Cayenne S (to pull the 944 to/from the track) for 10 days now and had similar questions - glad you guys are here! I spoke with a tech at my dealership this morning about installing a brake controller - he said that they don't install brake controllers there, but that just about any U-Haul or other place that sells towing equipment could install it for me. He also gave me a couple of pointers in general: - No more than 15 amps total, if you need more (probably anything above class III), then you will have to wire another circuit - No LED trailer lights. There is a conflict between the controller in the Cayenne and the controller on the trailer for these lights, and they will not work. Other than that, he didn't know of any other major issues... Hope this helps!
