olwe
Everything posted by olwe
  1. olwe
    I followed the thread onyour failed ABS pump. Do you still have the pump with the part number ending in 58?Do you still
    Read more
  2. My transmission recently had two glitches when driving on Sebring at high speeds: 1. It went to "limp home mode" (third gear and no indications on the dashboard as to what gear it was in or what position the shifter was in). A red light came on the dash indicating the problem. 2. It stopped driving totally, as if I had moved the shifter to neutral. In both cases things would reset if I stopped. For glitch number 1 I had to stop and re-start the engine for it to reset. For glitch number 2 to reset I had to stop, put it in Park, and go again. I have a transmission leak. Could the above be a result of low transmission fluid level? We did check error codes with an aftermarket code reader. It would connect with the engine ECU and give a TipTronic issue including that the transmission had slipped, and something about low voltage.
