flxzcat
Everything posted by flxzcat
  1. The wing might be drawing more hot air past the sensor and local sheet metal thereby raising the temp in heat soak? Just a thought...I don't even know where the sensor is located. Paul
  2. BMW uses a very similar key. The key cutting machine may be the same. Paul
  3. I have not seen a 996 thermostat yet. Does it have a bleed hole in it as many other cars do? Paul
  4. Thanks Loren. The thing is, I can only pull up the first page with the tire sizes?
  5. Does anyone have a copy of the factory or factory like drawing of the rear fender modification for 996 narrow body that includes the bumper cover modification? This drawing had dimensions and cut-away views. I may have seen it on this site but forgot to save it and now, no ammount of searching has turned it up. Thanks in advance, Paul
  6. Can someone tell me how to remove the hose/valve connector to the brake booster can? Is it a twist and lock or held by the vacuum? Do I just need to pull it straight out? Thanks in advance, Paul 2004 40th Anni Carrera
  7. Ah, so the two side radiators are actually larger than standard 996? Thats nice to know. Frankly I'm just amazed with the performance. I have owned two 930's and two 914-6 3 liters and I can say the 996 Anni has them beat in every way. Cheers, Paul
  8. I just got my 40th Anni this week, and I noticed it did not come with the third radiator that many books claim they have. Really love the car!!
