evoroadster
About evoroadster
    Honolulu, Hawaii
    2012 Cayman R
    2007 BMW 328i
    1999 Volvo XC
  • Future cars
    2012 BMW 328i
    1958 TR3a
    1964 AH Sprite
    1964 Malibu SS
    1964 Impala SS
evoroadster's Achievements
  1. About how long? Its been 60 miles and several engine start/stop cycles?
  2. Comments on latest oil analysis appreciated:
  3. Car has been running fine. Like I said, did some maintenance to the cooling system and changed a dragging starter. Last task was to change oil and filter. Found debris in filter element so I decided to drop the pan and there they were. The RMS was changed by a previous owner 6 or 7 years ago along with the IMSB.
  4. Seems to be ferrous. Most picked up by magnet. IMSB changed 7 years ago. Will be dropping oil pan later today and I have sent off for an oil analysis.
  5. Yes, the big one going from thermostat to pipe to front radiators. I disconnected the snap in place end during water pump, thermostat and coolant reservoir replacement and ended up with a massive leak at he snap in place end. Ordered new hose, lightly lubed the o-ring, reassembled and still have a small leak. Is there some trick to these hose ends?
  6. 2003 Carrera coupe, 54K miles: I am working on finding what is considered normal for these cars. In this instance the oil pressure fluctuates slightly when warm at idle. Once underway it is relativly steady. Pressure readings are fine for the load and rpm when underway.
