gscojo
Everything posted by gscojo
  1. That worked, thanks much!
  2. Hi, CDR-220 I've got SN x5030726 Thanks, Gary
  3. If you have a CDR-220 you can order an Aux Jack cable from Becker of North America. Part number BNA-1319.116. This cable plugs right into the back of your radio and into the aux jack of your I-Pod. Cost of mine was $29.36 delivered.
  4. Anything else I should check? Possible ground problem? I would take the battery in and have it tested on a commercial tester...just to be sure.
  5. Handy site to calculate different tire dimensions
  6. With that much Mobil One I think I'd wait untill I could replace the filter also.
  7. Again, hello to everyone & I welcome any and all suggestions! Fuse E1 (7.5 Amp) controls the radio. Fuse D5 (15Amp) the lighter There's also D9 which you may not have...controls Sound Sytem Option Pack and E1 controls Radio Terminal 86s Alarm Control Module.........whatever that is. I would also check the back of the radio for loose connections. BTW....if it's what I think it is, the cd changer is nothing more than a cd holder.
  8. Are there any sagging issues with the new style around the wheel well?
  9. Very nice! What are your rim widths and offsets (good clearance?) and are the silver dash parts tequipment, aftermarket, or did you have them painted?
  10. Thanks for the replies. I have the clips and no matter how I adjust it after a ride over fifty or so it's buldging again.
  11. Yes, the car is in a heated garage, I'm beginning to doubt that it will ever be warm enough outside to try your suggestion. I hate bras myself but, the car had no chips in front and I want to keep it that way.
  12. My 2000 Boxster's bra doesn't fit very well around the outer part of the headlights. It's a factory bra, had same problem with Colgan bra (both are very similar btw). It appears to be the nature of the beast but was wondering if anyone has a solution to the problem?
  13. Currently on the OEM 17's. The wheels were on a 2000 996-C2 and the owner claims the ride wasn't bad.
  14. Am looking at a set of 19's for my 986 (base) and wondering if they will fit. Fronts are 19/8.5/et52 with 235/35's and rears are 19/10/et52 with 275/30"s. Thanks for any help
