ekstroemtj
About ekstroemtj
    Frankfurt / Germany
    Audi S5 V8
    Porsche Cayenne S
    Porsche Cayenne Turbo S
    Nissan 370Z
    Nissan 300z
    Porsche 911 Carrera 3.2
3,229 profile views
ekstroemtj's Achievements
Community Answers
  1. Sorry I just have seen your message. Is the water problem still present?
  2. Sorry, I should read more carefully. i guess the reason is your work on the electric/ can bus. can you go back and try it again with the original wiring?!
  3. air hose. Feeding your compressor for air suspension.
  4. Did you check the wiring going to the coils? High temperature makes them really brittle
  5. Just want to report the end of the story. Replacing the fuel pump didn’t change anything. Only after getting a new fuel filter the codes disappeared. No more blowing fuses. Everything ok. Car passed the emission test. Very happy. Actually not very difficult this job. Lots of DIY reports everywhere. Just it’s a mess to work inside a fuel tank. Thank you for following and supporting
  6. Hi, just read your post. Having the same problem. Could you explain please how you solved it. Tank you
  7. Codes solved Just want to report the current situation - i have changed pump driver side / codes remain - i have changed the fuel filter / codes gone. tank fuel with 60 liters. Fuses ok. Car runs. No codes. just a very high fuel consumption on the display. what could it be? O2 sensors mass air flow sensors thank you
  8. My best regards to belgium . Thank you. I have seen your post before. Still in process to discover where the wiring is going along. Will report what i found out. thinking if it makes sense to install the new fuel filter before i continue with the wiring. A clogged filter can cause this fuse problem too - a Porsche mechanic told me
  9. Thank you for your feedback. Iwill let you know how this story is developing
  10. thank you Loren. Is the fuel pump powered by this connection? can i find a wiring diagram , better would be a overview where the wires are going along from pump to relay / fuse box. thank you and excuse that i take your time.
  11. I have tried a lot today but unfortunately without luck. Can do whatever, fuse number 13 gets always burned. To much power there. Open the plastic cover to get access to the DME. Cleaned the contacts. Without luck
  12. Thank you Loren. Many possibilities. Fuse and relay are ok. Pump is new now. dont know where to start to look now
