b756
    atlanta
    boxter
b756's Achievements
  1. Thanks Loren,I'll give it a try!!
  2. 1996.996 coupe. Any ideas on these P-codes,and what the fix might be? P-1691 P-341 Car failed e check and CEL bulb has been replaced but does not illuminate on start up. Re- P341,the camshaft sensor has been replaced. Thanks Jeremy.
  3. Thanks,is the synco something that can be repaired,or does it mean a new gearbox?
  4. Any ideas on a noisy gearbox,C2 1999 6 speed,when changing gear from 1st to 2nd and on decelerating from 3rd to 2nd the gears will sometimes make a loud grinding noise,happens every 10 or so shifts,the more revs the less likely the noise. I've looked at where the gear shift linkage enters the transmission and there seems to be quite a bit of free play on the bushing.thanks for any info.(and where to get a recond trans)!!!
