colinmartin
Everything posted by colinmartin
  1. sorry i meant the airbag with the controls for radio etc. which mine has none..
  2. 2003 ctt tiptronic hi guys i was thinking about buying a multifuntional airbag for my baby ,it hasnt had one on there since i have owned it, but who knows before .from what i have been reading there isnt allways a cable in the original wiring loom to even install it .my question is what do i need to look for to see if i have the connection installed and where it might be hiding .. thanks
  3. thanks for al the info i will take a look..
  4. 2003 ctt 90.000 miles hi guys the last few days i have noticed a little black smoke from the exhaust when i start her ,it only last a couple of seconds ,it doesnt seem to matter if its hot or cold and i dont know long it has been happening ,as i said i spotted it a few days ago so now i look everyday,my question is ,do you think my turbos are on there way out? or is it normal as we tend to use more oil than other cars? im a little worried as i have just given her to my car painter and would like some piece of mind as to weather im going to be forking out for turbos after the paint job..thanks for any help
  5. 2003 cayenne turbo pcm cd based hi guys i recentley installed a denison 500 in the car so i could listen to my usb stick, its a bit of a pain going through the folders on the pcm screen a bit slow loading information but its all i can do without changing the whole system which from what i have been reading is not easy , but i would like to have bluetooth phone as this is the 21st century, they say i can buy a dension BTA bluetooth hands free adapter . my questions are has anyone got this installed? does it work? my unit is installed in the cd changer location .it has a microphone will the cable be long enough to reach the front? thanks in advance
  6. hi i understand that was for the cowl drains but thats what was causing the footwell to leak it filled up and come in from behind the glovebox..
  7. hi i had the same problem i have just fixed it ,you need to take out the plastic arch liner there are quite a few screws but after you can see everything very easily ,i have had this happen to me twice now so this time i removed the drain gromet it leaves a large enough hole so it shouldnt happen again..
  8. it seems to have worked for now i will keep you posted
  9. er no i will have a go at that thanks..
  10. thanks for the reply actually the problem is local adrresses and it doesnt just happen in romania .also if i try to play a cd that was made on computer it rejects it ,is that normal as well,i installed denison 500 because the cd changer gave up the ghost. i have had to buy another gps which sucks.from what i understand it is not easy to upadate to a later pcm because of the bose. why is it the chinese can make a plug and play system but porsche cant be bothered..
  11. hi ive started getting problems with my pcm ,i installed the maps and everything runs ok the map moves where it is supposed to but when i enter an adrress it keeps saying install cd ,i have even loaded other country cd `s and reinstalling the correct country to no avail .has anyone got any ideas?
  12. 2003 cayenne turbo hi guys i just went through the car wash today and i had water coming in through the passenger sider it looks like it up by the back of the glovebox ,i checked under the hood and it looks like the compartment where the heater pipes sits is full of water ,probaly the drain hole is blocked ,does anyone know where it is located ?thanks
  13. i had the same problem with mine if i open the whole tailgate it seems to engage ,
