986CHUCK
Everything posted by 986CHUCK
  1. Loren, Thank you, saves me from buying 2 pumps.
  2. is the secondary air pump the same on my 1999 Carrera the same part as a 2000 Carrera. when I look it up it shows: 1999 part: 996 605 103 01 2000 part: 996 605 104 01 Just trying to clarify if I can use the 996 605 104 01 on my 1999 Carrera.
  3. Loren, I know you have helped me with this in the past. Just picked up a 2000 Boxster S and I am in need of the radio code. CDR 220 Serial #: Y5036438 As always, Thank you
  4. Try 1013 or 1011 Thanks, That did the trick. Loren, It seems that I was mistaken the 1011 or 1013 code does not work. I have checked and my radio ser# is correct (15076978) Would you be so kind as to check for the code again. Thank you. 1013 is the code that I come up with - try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.) Thank you it was 1015 and the radio is up and running.
  5. Try 1013 or 1011 Thanks, That did the trick. Loren, It seems that I was mistaken the 1011 or 1013 code does not work. I have checked and my radio ser# is correct (15076978) Would you be so kind as to check for the code again. Thank you.
  6. Try 1013 or 1011 Thanks, That did the trick.
  7. I am new to this so be patient. I am in need of my radio code I have just bought another 2001 boxster s radio: cdr220 radio ser#: 15076978 model: BE 4462 Please Help.
  8. I have the EVO intake on my 06 C4S no problems. Was thinking it would make an ircreased sound of air intake, but I can hardly tell unless the top is down. I also had the GIAC flashing to the ECU.
