Silver_TT
Everything posted by Silver_TT
  1. Never a great approach to use the "parts cannon" rather than true diagnostics. You can't use a generic OBD scan tool with these cars, don't waste your time. Buy a Durametric which is able to read the proprietary codes and give you something of meaning when you are diagnosing issues. I also suggest buying OE parts from Sunset Porsche using your VIN to ensure correct fitment rather than trying to guess that a VW Toureg part is the same. Lastly, you may want to check your battery. I have seen a marginal battery cause all sorts of weird electrical gremlins. Just about the only thing I would do as far as throwing parts at it would be to replace the battery with a high quality AGM if the battery is aged.
  2. That's a big difference between the first two estimates -- likely they are not apples to apples. And, ya, it is normal for the collision department to send the car to the dealer for the recalibration. That price sounds about right since dealer rates have gone up and it's likely a 2+ hour procedure to perform the calibration.
  3. From the looks of it I don't think the paint will peel or worsen in the near future....... maybe if you don't get it fixed eventually it would but I don't think that's going to get materially worse on its own anytime soon. Once they do the repair they can make that look like it never happened. Whoever you have do the repair, it never hurts to explicitly ask/tell them to recalibrate the sensors back to 0 deviation.
  4. All shops are very busy right now. My indy is scheduling work 6+ weeks out. The warning messages aren't normal. Do you use VCDS? You can check the lane assist faults but your dynamic angle offsets are too large. There is a static offset which is the initial position at calibration and then dynamic offsets from that -- the dynamic offsets have a tolerance that is somewhere around 7 degrees. For example this -7.51 tripped a fault: And looked like this after the dealer recalibrated (2 hours labor, insurance paid for it): The dynamic angles will change as the car's computer samples them periodically. My lane assist would intermittently work as that dynamic angle was close to the 7 degrees trigger and would sort of bounce around near that 7 degrees, sometimes over, sometimes under. You have to force them to recalibrate it after an accident. My wife had a minor accident a year or two ago and when I picked up the car and used VCDS I saw that they had not recalibrated the angle offset back to 0 (and went back in told them and left the car there for another day for them to do it like they should have without me having to check). This is probably similar to what happened in your case.
  5. This is what insurance is for. I would have a Porsche certified body shop fix it. You won't be able to touch it up by yourself and having a 3rd party shop do it is more risky for several reasons. The sensors may need to be recalibrated if your bumper moved at all. For example my Audi Q5 has lane change assist and there are radar sensors all over the car that are calibrated. If they move because the bumper has moved or been hit, even by a very small amount (I forget the amount it's like 7 degrees), it can cause the system to become inoperable. Paint job for that is typical to take a week.
  6. My Audi Q5 has the ZF 8HP and that’s correct, there is a fluid for the gearbox and a separate different oil for the transfer case.
  7. You checked the cylinders? If it had bore scoring you would see it on the cylinder walls. The specifics can vary depending on if you have a 997.1 or 997.2 but generally the scoring is going to start from the bottom so it makes the most sense to go in through the sump rather than the spark plug holes. This video may help:
  8. Looks sick!!! Love the chalk color........
  9. Assuming you already checked the easy things like crankcase vacuum (AOS), drop the sump and use a borescope the inspect the cylinders from the bottom. The cylinders may have bore scoring.
  10. Someone over on Rennlist bricked their transmission recently playing with a PIWIS clone. Avoid........
  11. One final thought is that Lee Jenkins of Hartech in the UK could also be an excellent resource. I have seen his work and it is outstanding, he is very very good.
  12. JFP spot on as always. Raby is going to be the best source for this. If you paid for the video I would contact jake. He’s usually a very nice guy when the questions aren’t stupid (which is why he left Rennlist)
  13. Sounds like you initially had the wrong group size. As far as CCA goes my experience with german cars is replace with same or higher CCA (never lower than factory battery’s spec).
  14. AGM has several advantages over lead acid with basically no drawbacks except for slightly higher cost. If you use a battery maintainer/charger I would recommend getting one that is "smart" (has a build in computer/electronics to keep me from doing stupid things) and for AGM batteries specifically. For example I have owned the CTek 7002 forever, before I even knew what a AGM battery was, and it has SNOWFLAKE mode, aka "the 6 pack", for AGMs (icon literally looks like a 6 pack of beer).
  15. Maybe it's not inoperable but it is blocking the drain hole and that is certainly not advisable as the moderator is saying. If that was my car and the tether is causing such problems, I would just cut the tether. All else equal that is a better solution than blocking the drain hole.
  16. Gbox… call Stan. He rebuilt my 996TT gearbox good as new
  17. ^THIS Gotten tons of good advice from JFP over the years but this is one of the best bits. Super useful to have for a Porsche engine, or really any engine and especially the newer DFI engines that run higher vacuum spec levels. All you have to know is the spec vacuum for your engines.... I built this exactly like JFP says to help a friend track down an oil consumption issue and to show folks in the Audi community that a PCV is doing more than regulating crankcase vacuum (it has several non-return valves and a combi valve which can fail, which can lead to increased crankcase pressure and routing too much blow-by into the turbo). Keeping an eye on your crankcase vacuum is very easy to do, taking literally under 1 minute
  18. Thank you for following up and posting the solution.
  19. Why? I understand that you never want to rotate the engine even if it is slightly out of time but if everything is in time why can’t to be rotated backward? Thanks for the info
  20. Call Sunset or I recently posted a thread from Rennlist with a supplier who sells it by smaller quantities. UNDER NO CIRCUMSTANCES should aftermarket fluid be used. It is not described as Audi fluid, it has its own Porsche part #. Sunset also sells Audi parts (they are Audi Beaverton) and the part number is completely different. Do not try to take shortcuts thinking the fluids may be the exact same as the consequences are very punitive. It's not worth the risk to save a few dollars IMHO and I know first hand having had to rebuild a gearbox due to the previous owner lying and using aftermarket fluid.
  21. Welcome back. Nice looking car. I like that the interior features a screen that is built in and not a large ipad-looking screen that sticks out.
  22. Yes there is a screen on the scavenger oil pump p.s. JFP's name is John outside of the metaverse
  23. Possibly from an old since replaced RMS that someone sloppy drilled holes for the removal screws in then it got chewed up inside the engine... so there is a new RMS in there now with spring intact. Yes, agree, the RMS was updated but this is still one of the most common leaking points on this engine.
  24. I see but how did it need a quart top up in 1,662 miles if you said it only burns a quart every 3,000 miles? Maybe you only added half a quart? Either way, mixing in a lower viscosity oil would explain, at least in part, the thinning of the oil... still seems pretty thin overall given that the majority was 15W/50. FWIW Blackstone's fuel dilution measurement isn't that reliable from what I have seen
