richardch
    996 Turbo
    Ferrari Stradale
richardch's Achievements
  1. Pls now count me out this thread is endless promises & no action b.sh*t
  2. How are we doing here with getting some produced
  3. In my 2001 996TT the Electric Seats is only working intermittently, which is a bit of a worry if my wife has to drive the car as she can't reach the pedals !Sounds like a lose connection somewhere I guess but it even when the seat adjustment works the seat memory function is permanently disabled ??
  4. Tvm I have the TT Manual I will mention that to them
  5. tvm Loren, does anybody have any suggestions for additional engine mods that can be done if the engine is coming out, new plenium intake / New boost hose kit etc ?
  6. They mentioned that the intake pipe was in the way and you can't even just drop the engine, you have to remove !!
  7. Hello Loren, On my 2001 996TT, I have a slow coolant leak. I took it to my official Porsche dealer and he notes that it is coming from the Electrical Water Pump, which needs to be replaced. I'm informed this is a full engine out job which takes at least 2 days. Any other thoughts or potential solutions ??? :o
  8. Loren, May /01 is just before the Bose system was introduced, I have a CD changer but no :rolleyes: amplifier that I can find correct ? or is it under the passenger seat etc
  9. tvm Loren
  10. I am told there is a brilliant thread on this somewhere here; I am 90% with it, my question is do I have to remove the rear wheels to take off the bumper as I need access the torx screws in the upper wheel arch lining (which is above the height of the bumper) or do I just need to undo the Hex nut half way up the wheel arch and the Torx screw at the base ???
  11. so in fact if you pull off the side covers of the lower central unit and the carpet, it is much easier if you just take the whole unit out and work on it by unscrewing the 2X Torx screws on either side holding it in the frame
  12. tvm Je texas, last thread particularly helpful
  13. I plan to remove my OEM Sat Navigation which is overheating and giving a disc reading error from my 2001 Turbo and replace it with a Garmin on the windscreen Is taking it out and easy job ? unclip and unplug and I guess I can order a OEM Porsche part to go in its place as a holder for sunglasses etc ?? :rolleyes:
  14. tx Loren this is all so depressing, effectively a no go, but all that kit weighs at least 25lbs and I want it out :P
