89 -
Last visited
Classifieds
Everything posted by JasonStern
I've got a 2002 996, only 26 K miles. It has a small oil leak, probably from the rms, but it's been trouble free for 8 years. From what i have read over the years on this forum, a small amount on the floor is no big deal, I understand this happens a lot. Any opinions on this ? BTW, I check my oil frequently, is there any need to worry about a tiny amount ? The car isn't a 1980s Honda where you can ignore maintenance, nor is it an (insert any year) Jaguar where the engine's life blood leaking out is acceptable - it's a Porsche. If you have had 8 trouble free years, bite the bullet and have the oil leak addressed. Outside of the RMS, which would have likely leaked prior to now, the M96 doesn't normally leak oil. But that is also a good thing as it means wherever the leak is coming from can hopefully be easily addressed. If the engine does have to be dropped to fix the leak, consider replacing the air/oil separator and, if it hasn't been done (recently), the IMS bearing with an LN engineering bearing, and also the clutch. No sense in paying the labor in dropping the engine twice.
Awesome. I might have an excuse to upgrade versus fixing the stock steering wheel. :D
- 2 replies
- three spoke steering wheel
- four spoke steering wheel
- (and 2 more)
Short Shift Kit Options
JasonStern replied to dinicor's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
The length of the shifter affects the amount of torque applied - nothing more. My previously owned 986 very likely had the transmission fluid flushed using an aftermarket transmission oil that was not properly speced to the temperature range that the car saw - presumably due to the previous owner not driving it in winter. With a proper weight transmission oil, a short shifter should exhibit no side effects. But if you are not the original owner and plan on installing a short shift kit, then it is worth noting that the cost of a transmission fluid change might need to be factored in, depending on the service history and weather that the vehicle is driven in. -
So the bushings on my 996's steering wheel are starting to fail, leading to the occasional connector contact being made despite no force being applied. This is a common problem. I did search. It can be fixed easy enough and I found posts explaining workarounds. But unfortunately I was unable to come up with a specific answer to this question - "Does the three spoke steering wheel suffer from the same bushing/contact problem as the four spoke?" Thanks!
- 2 replies
- (and 2 more)
The M96 ticking at start-up is common, as it is a boxer engine and oil drains causing the top lifters to be under-lubricated until oil flows through them. Likewise, the M96 uses a timing chain as opposed to a timing belt, so you're going to get more noise at start up until the tensioner is fully pressurized. When you first start it cold, blip the throttle above 2k RPM. This isn't going to hurt anything - the Bosch Motronics temporarily increases the RPM above idle at startup (although not to as high of an RPM as it probably should), and plenty of people drive the car with the engine cold to 3k+ RPM without any problems. On my 996, this stops the ticking. If ticking persists, especially when warm, then stop driving the car. Drain the oil and get an oil analysis done. Cut open the air filter and look for any metallic flakes. Worst case, you get a preemptive oil change. Best case, you identifiy an impending engine failure before too much damage is done.
- 2 replies
- porsche
- engine tick
- (and 7 more)
Copy/pasted from a post I made on Oppositelock about Porsche Boxsters, but it's still relevant: do yourself a favor with the cheap Boxster - save up an extra ~$2k-3k, and when you buy it, go to a local independent Porsche mechanic and have an LN Engineering IMS bearing installed, the clutch replaced, the rear main seal replaced, and the air/oil separator replaced. replacing the water pump and spark plugs would also be worth considering. the M96 is a solid motor once its weaknesses are addressed, and it costs a lot less to drop the motor once and address everything than it does to fix issues as they arise. plus, you'll have the peace of mind in knowing that everything has been addressed.
Metal bits..
JasonStern replied to 911 dreamer's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Worth noting: If you switch to a magnetic drain plug, the torque specs will be different. Make sure to remember that to avoid having the magnetic oil plug fracture due to being overtorqued following a "by the book" oil change. Blackstone Labs provides an engine oil analysis that helps indicating what metals are present, which helps identify what metals are wearing at what rate. Given the M96's history, I personally feel that it is worth the investment - especially if you are already finding metal flakes in the oil filter. -
MAF Sensor
JasonStern replied to Philip54's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Right now my engine light is off and Durametric is showing normal values for the MAF. So I'm taking a wait-and-see attitude. But thank you for your advise. When my MAF was going out, it reported correct values as far as the Durametric was concerned. And pitching my indie repair shop the idea of "just drive around for 200-700 miles until something happens" wasn't something that they were too interested in. At first, I had the same self correcting MIL not illuminating a bit after a fault. But on a long enough timeline, the problem came back. And given how sensitive these motors are, I personally don't like the idea of running the motors too rich or too lean for an extended period of time. That said, if this is the first time the code has occurred, I completely agree with clearing the code and seeing what happens. But taking the MAF out and cleaning it first might be cheap and easy insurance against the problem reoccurring. -
More often than not, cold weather shifting effort problems are the result of the wrong gear oil rather than the shifter. We have installed a lot of short shifters, mostly B&M, and as some of the cars are used daily in zero and sub zero ambient temperatures without any shifting issues, while others have had poor cold weather shifting even with the stock shifter when using aftermarket gear oils which were completely remedied by going back to the factory fill, it is difficult to blame the shifters. I completely agree that, given the effect that temperature had, an improper weight of gear oil was likely used. But short shifters lack the leverage of the stock "tractor" shifter, which further exacerbates the side effects of running an incorrect weight of gear oil. Ultimately, I didn't own and drive the 986 long enough in cold weather to try replacing the gear oil, and was lucky enough to land a 996 that had service records so I have a more detailed record of what exactly the previous owner did. :D -
MAF Sensor
+1 on the MAF's lifespan not being mileage based. Mine started exhibiting problems after about 25k miles, but that was also 15 years. If you are unsure the age of your MAF and O2 sensors, replacing them is fairly straight forward and tends to be cheaper than paying a shop to try to diagnose the problem. Worst case, you have eliminated them as potential problems and now have a spare set of sensors. -
My 986 had a short shift kit installed by the previous owner. I am unsure the brand, but I recall it being difficult to shift at first in freezing weather. At first, I feared something might be wrong with the transmission, but apparently that is a common problem that may or may not be reduced by switching manual transmission oil weights. When I bought my 996, the stock shifter's throws felt like driving a tractor versus a sports car. I went with the 997 shifter. The shifts are a bit longer, but it hasn't exhibited the cold weather problem, likely due to the additional leverage the longer throw provides. Likely irrelevant, but I like it from a purist standpoint in the sense that I am still using factory parts. IIRC, two 997 shifters are available. I went with the cheaper one that did not have metal bearings as I do not shift like a madman. Regardless of what you go with, it's one of the only modifications that I have done to my 996 and it is well worth it. -
The rates seem excessive. If you aren't the DIY mechanic type, then the coolant I wouldn't touch. With the engine in the rear and the radiators up front, it's easy to get air bubbles that affect the car's cooling ability. The oil changes are fairly straightforward. I recommend doing that yourself so that you know it is done right. Also, this allows you to install a magnetic oil drain plug so you can periodically check for any potential IMS bearing debris. Likewise, you can cut open the oil filter and use a magnet to search for any unexpected wear. Plus at the price the dealership is asking, you can buy an oil with a high ZDDP content and send an oil sample off to Blackstone Labs to have an engine oil analysis done for roughly $100 less than they would charge. My girl is cutting me off from the PC, so unfortuantely I can't voice my opinion on the rest.
Water pump
+1 for Ahsai's recommendation. Best case, you average 60MPH at which point you're running ~2,500+ RPM for 6 minutes straight with zero coolant circulating. That sounds like a recipe for a cracked head/cracked heads. But if you want to gamble a $10k motor to save a $75 tow fee, the internet can't stop you... -
IMS "death rattle" ?
JasonStern replied to hindswillrox's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
Hitting government mandated MPG levels - remember, the manufacturer is only on the hook during the warranty period. Mazda proved and burned themselves on that with the RX-8/Renesis... -
2003 911 C4S - Opinion on Value?
JasonStern replied to bdblair's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
If you're looking for a C4S, I'd consider also looking for a 996TT. In many cases, the price difference between the two is surprisingly not that large. And for the difference, you get a more reliable motor with a higher chance of appreciating over time. Something to think about, at least. -
Rear tire recommendations
JasonStern replied to steve20186's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
I hope that you are also weighing the cost of getting into an accident versus the additional cost of buying quality tires when you make your decision. What I run - car driven year round but with zero track time and zero snow exposure: Warmer Months: Michelin Pilot Sport Radial X 225/40/ZR18 front, 285/30/ZR18 rear on BBS Sport Classic II rims. When they wear out, I plan on replacing them with Michelin Pilot Super Sports. Cooler Months: 225/45/17 Kumo Ecsta ASX front, 255/40/17 Michelin Pilot Sport A/S 3 rear on Boxster S rims When the fronts finish wearing out, I plan on replacing them with 205/50/17 Michelin Pilot Sport A/S 3s. In my opinion, spending for the Michelins is worth it. I highly discourage running a summer tire in the colder months, as traction is reduced due to the tire not being run in its ideal temperature range. To work around this, I use a set of Boxster S rims with all-season tires in the colder months. With the exception of the Michelin Pilot Sport A/S 3s, all of my tires have come from previous owners. The Kumho Ecsta ASXs that originally came on the Boxster S rims are great for a budget tire; however, given the rear weight bias and tendency to snap oversteer, I try to avoid budget tires on my 1999 C2. While running mismatched fronts and backs is not recommended, I'm doing so because I drive significantly less aggressive in the winter months, and with the weight bias and rear-wheel drive, the rears tend to wear about twice as fast as the fronts. Also a good read from a former Goodyear/Michelin employee: http://oppositelock.jalopnik.com/im-going-to-put-my-0-02-in-here-too-ok-his-got-rea-1175560222 -
unless you're as knowledgeable as JFP in PA or Loren, definitely pay to have a pre-purchase inspection done. the worst case is what happened with my 996 - the mechanic said it was the nicest Carrera he had seen given the age and I wasn't able to talk the guy down any. that's a much better position to be in than the worst case of not having a pre-purchase inspection done, as others have already proven. I disagree. if you want a daily driver, avoid ultra-low mileage examples as they likely have been sitting and issues may arise from that. but more important than the year and mileage is going to be how well maintained the car is, whether or not the car has full service records proving that required maintenance was done, etc. another thing worth considering when buying a 996 is to put away extra money at the time of the purchase, and then just go ahead and pay to have common problems addressed - upgrade the IMS bearing, replace the rear main seal and air/oil separator, have the clutch inspected and replaced if needed, etc. by doing that, you will likely have peace of mind and save some money by combining the labor of multiple repairs.
How to remove stripped drain plug?
JasonStern replied to LVDell's topic in 996 Series (Carrera, Carrera 4, Carrera 4S, Targa)
From personal experience, I have about 15k on a M96 powered Boxster and just under 5k on a M96 powered C2 running LN Engineering's magnetic drain plug without any apparent negative side effects. I'm not sure what problems the plug could cause, as the torque specs are reduced and a copper crush washer is still used. If any magnetic metal shavings were circulating around in my engine, I would prefer they stuck to the magnetic oil drain plug making their existence very easily noticeable at the next oil change rather than have them circulate throughout the motor. -
I have an oil change coming up and I plan on changing the air filter in my 1999 C2 at that time. Is it worth pulling the MAF and cleaning it while I'm there? Last time I checked it with the Durametric, the readings were in spec, so I don't think it's that dirty. I am just unsure whether periodically cleaning it will extend the MAF's life by reducing the likelihood of build up, or if it will reduce its life due to applying chemical cleaners. Thank you!
Just a check-in. The fuel flow rate measured fine, so I continued with the adding fuel injector cleaner and just driving it approach. Eventually, I had one hard start and took it into Reno Rennsport. They ran the same tests I did and ultimately came up with "Try fuel injector cleaner! That will be $220!" which honestly was worth it to ensure I wasn't misjudging anything that might potentially cause more severe problems. I told them, if you just drive the car 100-700 miles, it will retrigger! But they passe on that, and said they would gladly start replacing random fuel related components hoping that it solves the problem, but at this point there is no guarantee. So, with the car seeming to run great and me not in a position to drop a quarter of the value of the car replacing every fuel related component, I'm continuing to just drive it with Techron added at each fill-up. Hopefully, either the issue resolves itself or more symptoms arise that can help identify the culprit. For safety reasons, I would like to start checking weekly the long-term FRA and TRA values to ensure that, while they are not ideal, they aren't at levels that could potentially cause harm. Does anyone know what levels should cause concern enough to stop using the car as a daily driver (no track time or aggressive/spirited driving)? Thank you!
I imagine a lot of it will be fairly similar due to fact that the dash forward and much of the motor is common common across both vehicles. However, all of the "upgrade your 986 using 996 parts!" sections obviously would need to be replaced, and if you don't own the 101 Projects for Your Boxster, it's a good reference and worth the ~$25 asking price.
If the paint has already been touched up, and done so poorly enough that the touch-ups are evident, then you are much better off short-term getting it resprayed. As DK570 mentioned, if you plan on keeping the car 30+ years, and I will add with the intention of reselling it and not enjoying it, then leave it alone and hope that there are better technologies available to restore older paint jobs.
- 9 replies
- 996
- front bumper
(and 3 more)
Tagged with:
