abusharkh
    UAE
    Other
    Cayenne Turbo
  • Future cars
    911 turbo
    camaro z28
abusharkh's Achievements
  1. Replacing Fuel filter Filter location underneath the rear seat behind the driver side Replacing the filter: Recommended to do this job while the fuel tank is almost empty Fuel tank located underneath back seat Gain access to fuel filter need to flip back seat and look under the carpet Pull the seat buckle below the seat and flip the seat bottom Remove seat mount hinge, note you need special socket to fit the nuts Find below a round cut made on carpet, open Find round stainless steel caver with four sc Author abusharkh Category Cayenne (9PA, 9PA1) - Common Fixes and Repairs Submitted 08/20/2011 03:18 AM Updated 09/30/2016 02:33 PM
  2. Filter location underneath the rear seat behind the driver side Replacing the filter: Recommended to do this job while the fuel tank is almost empty Fuel tank located underneath back seat Gain access to fuel filter need to flip back seat and look under the carpet Pull the seat buckle below the seat and flip the seat bottom Remove seat mount hinge, note you need special socket to fit the nuts Find below a round cut made on carpet, open Find round stainless steel caver with four screws, open it Then you will see the filter Use special tools to open the lock ring or use big flat screw driver with light hummer to remove the ring, slowly slowly, hit from different angles and corners to distribute the hummer pressure, Then disconnect fuel hose and electrical connection from top, be careful fuel house might be under pressure Note: petrol smells very strong and harmful, do this job in good ventilated area Note: there is a house connected between fuel filter on the left side of the fuel tank and fuel bump at the right side of fuel tank. Go to the right side of rear seat and flip the seat Find carpet cut same as left seat Remove seat mount hinge, note you need special socket to fit the nuts Open the stainless steel cover Find the plastic cover same as fuel filter housing Open the lock ring Then disconnect electrical connection and fuel house from top of plastic cover Be careful fuel might be under pressure Pull the plastic cover up, look down you will find a house that going to the filter at left side and some other house going to fuel bump, pull the house which is going to filter side several times back and forth to make sure it is the correct house going to filter side Then go to filter side on the left and remove the filter and note the house going to the right side, and pull to make sure that this is the right house going to left side After you are sure of the right hose Go back to right side are and tight the house with a string (or any available robe) before pulling the house this string will help you pull back the new house for the new filter back to the right side, Unplug the house go to left side and slowly pull the filter and un plug the other house and wire connection at the bottom of the filter side and make sure to tight the house and wire connection with strings to make sure not to fall down inside the tank bottom, Note: much petrol will comes out from filter After removing old fuel filter bring the new filter and first thing to do is to tight the string we all ready have from the old filter house side and insert in the fuel tank and pull slowly to right side Then connect back house and wire connection of the filter. Go to right side pull the string until you catch the new filter house and connect back to the plastic cover and put back all parts. Go to right side and put back every thing once an again.
