renos
    Nicosia
    Carrera S PDK
    Audi Q5 TDI
    VW Polo TSi
  • Future cars
    Macan
    911SC 3.0
    Boxster S
1,112 profile views
renos's Achievements
  1. If the gear box was not exposed to heavy loads or high temps, you are probably fine. I would make the suggestions to re-change the gear box oil again in about 500-1K miles, just to make sure all of the wrong fluid is flushed out of the system. The Pentosin product is a hydraulic fluid, not a high shear lubricant which is what the gear oil is. As long as nothing was galled or bearings overloaded during the mix-up, and all of the Pentosin is flushed out, the gear box should be OK. Thank you for your reply and your recommendation for re-changing the oil. The ambient temperature was around 18 centigrade. During my 100 km drive I used high revs and sequential changes several times, but it wasn't as if I was racing. Would any potential damage show immediately or would this appear after a long time?
  2. A workshop mistake took place yesterday on my 997.2 S, PDK. I had the clutch fluid (Pentosin FFL3) in the PDK Clutch compartment changed last month at six years. On the annual service I asked for the transmission oil in the gear compartment to be changed as well. They put Pentosin FFL3 again instead of the 75W90 Mobil Lube due to a workshop mix-up!!!!! I discovered the mistake by looking at the lubricant part number and the on the invoice but only after I drove for 100 km. The gearbox will be drained and flushed and filled with the proper lubricant. BUT should i worry about premature gear wear because i drove with the wrong fluid in the gear compartment? Your views please will be appreciated!
  3. Adjust the front trunk cover so that it is slightly below bumper and the whistling noise will go.
  4. I've got a 4 page Porsche document I could e-mail to you. Basically, Some options will be made standard and a third radiator on PDK cars. The rest are new colours and cosmetic changes for the steering wheels.
  5. Mine is a 2009 model (manufactured 12/2008) and the sport and sport plus displays light up (left spoke). I was told that the LC display (right spoke) only works on 2010 cars.
  6. I've had it retrofitted last week. It works very well and it is a great improvement most of all because the shape and size of the paddle wheel is more ergonomic than the original. I paid 970 Euro fitted.
  7. Porsche as from this month offer this as a retrofit item from Tequipment. It's a straight swap but you need the PIWIS to activate certain things.
  8. Engine off: Zero for sure Engine on: approximately 1 bar for 1000 revs
  9. Why not the Porsche Sport Exhaust? Switchable and within the warranty.
  10. I've been waiting for information on the new model release before deciding what year to purchase. Did you find this info on Porsches website? Low range and locking diffs are expected to be optional (like on the current Mercedes ML). Rumour is that on the normal cars PDK will be used whereas the off-road optioned cars will be fitted with a torque converter automatic.
  11. Most probably faulty MAF sensor. That was the problem on a 986 I used to own.
  12. The telephone module (option 666) works readily with phones with SIM Access Profile (SAP). Such phones are several Nokia and Blackberry models shown on the Porsche web-site. Check them out here: http://www.porsche.com/all/media/pdf/Bluetooth_uk.pdf For other phones to function some change of settings is required using PIWIS and in the case of those phones not all functions are available but still you can make and receive calls using PCM and the MF steering wheel if you got one. No other hardware is required unless you wish to order the wireless handset in order to make calls in privacy avoiding the loudspeaker.
  13. I know someone who has had a MF wheel installed on a 997.1 Turbo. The job was not a straightforward retrofit, it required improvisation on the electrics and was done by an independent workshop. The technician who did it told me it was difficult. I don't think OPC would do it if it's not in the book and the car under warranty.
