GOLENJEEPTJ
Everything posted by GOLENJEEPTJ
  1. His profile only says 2005 911
  2. You have to purchase the CDs. When I had the old stock NAV head in mine I did so by purchasing the CD updates from Porsche and they're not cheap!A few Hundred dollars! I'm am thinking about selling mine?
  3. I just replace my head unit with a Pioneer AViC-8200NEX and I could not be happier!!! What memory settings are you worried about? I have all and more! I also have a 06 C2S with 38k miles on it! You wont regret the touch screen and all you can do with it!!
  4. Agree with wizard ^^^ Have the tires rebalanced on a "Hunter Road Force" machine.
  5. My 06 C2S redlined at 7000 stock, now with an ECU Flash (tune) it redlines at 7500rpm.
  6. I too have the same setup and I would be very interested on knowing also?
  7. Yes you have it, your just missing the DVD. It's located in the trunk, just look in straight ahead and you will see a release latch just above the tire well.
  8. After all was said an done with the LN adapter & Napa Gold Filter, mine sits higher than stock with no chance of being hit.
  9. There are 2 & 4 wheel drives. Carrera 4 & 4S are two seperate models both AWD (All Wheel Drive). The Carrera & Carrera S are again two seperate models but both 2 wheel drive which also know as RWD ( Rear Wheel Drive).The S does not stand for plural.
  10. I am sorry to hear about your problem with your Softronic software. I have had Softronics for about 2 years now and never a problem! Did you ever once try reflashing your DME back to stock?Also it sounds like you have never done a reflashing back to stock yourself?
  11. Like said above, could be anything?An auto stethoscope is the way to go.Good luck!
  12. I have the Dension 500s Gateway.I've been extremely happy with it! Call Bumper Plugs and ask for Eric!https://www.bumperplugs.com/
