dylanjl
Everything posted by dylanjl
  1. Hey how are you? Is this battery coding for cayenne turbo's a real issue? I have read differing opinions, where some people say its not required..I am having some issues and the dealer insists that its because I have an aftermarket battery which is not coded for the car, and they want me to install an OEM battery and recode it. My trusted and regular indy Porsche shop cannot pinpoint the issue with my car, however he doesn't think the battery coding is necessary. I trust him, but need to get my car sorted...already replaced ignition switch and brake switch, was thinking about the battery relay. I don't want to spend big bucks on a "Porsche" battery from stealership if its a "scam"..thanks in advance. Sincerely, Dylan
  2. If anyone could please help me out with diy for replacing SAI check valves on 04 cayenne turbo, it would greatly be appreciated. Cheers Dylan
  3. Where is the diy? If I click the link above it takes me to a boxster forum??
  4. Logray you are awesome Thanks! Would you say I could go ahead with an IMS upgrade then? Cheers!
  5. Yes logray Although I thought the " 7" could possibly be a "/ " as well ?? I also see M96/01 66W 07551 AT Thanks for your help!
  6. https://www.facebook.com/photo.php?fbid=10151646577716211&set=a.10151308513171211.507949.602511210&type=1&theater sorry cannot figure out the correct way to upload a photo..
  7. Thanks for all the help guys! I was looking at doing An IMS update as a preventative measure but wanted to make sure my engine didn't already have a similar update..
  8. Ok Is that a good thing.. Like maybe engine will be more reliable? Any known issues corrected at time of replacement I hope..
  9. My engine serial number indicates MY98..is this normal on a MY99 Carrera? Also, there is "AI" after the number "551" right at the end of the serial number..any idea what "AI" indicates? Thanks
  10. thanks I will check the engine serial number..where is the easiest place to find it?
  11. Hey guys I have had my 99 Carrera for a couple of years now..I have always wondered about the engine specs. I know the MY99 is a 3.4l engine...but on my car, the plate inside the engine bay cover states displacement: 3596cc....which is 3.6l...is this correct or do I not have the original engine that the car came with? I need to order some parts now so need to make sure I order the right stuff. Your input will be greatly appreciated. Regards Dylan PS If it helps I can attach a photo of the specs inside the engine bay..
  12. what was the issue in the end? have same problem....
  13. Thanks, but can you also identify which pulley is the 118 upper and 119 lower...I cannot find any identifying part numbers on the actual parts and they have been removed from the boxes...or does it not really matter...? Regards, Dylan
  14. I just ordered new idler pulleys, both upper and lower 997 102 118 00 and 997 102 119 00, for my 99 carrera. My son removed the pulleys from the packaging and now I cannot tell which is which..they look both the same with the exception of the washer on one side...I didn't see any part number on the pulleys (I must be blind) and since they have different part numbers on the packaging, it must matter which one goes where. Can somebody please help me identify which one is upper and which is lower please...I posted a photo underneath. Thanks in advance, Regards, Dylan
  15. I ad exact same issue in my 99 carrera..deutsche parts pump failed after about 1500miles..I also only bought it because of the metal impeller which was recommended on some youtube videos. The lesson I learned: not worth saving a few bucks on el cheapo aftermarket parts promising that "made in Germany"=good quality...bought genuine Porsche part now and will install next week.. Will never buy aftermarket rubbish again...now I have to do the job again.
  16. i removed belt again... water pump pulley has some play as well as lower idler pulley...should i just replace them?
  17. thanks for the info....just weird that the sound only started 2 months after water pump replacement.it was perfect till now..so was just hoping it was not related?? but will keep an eye/ear on it. Cheers!
  18. HEY, I followed JeTexas's excellent DIY video to change my waterpump... I also changed the alternator and polyrib belt previous month...I bought a decent looking replacement water pump from autohausz ..oe fitment etc...now after exactly 2 months..I hear a belt noise from the rear..no bearing/grinding noise...car runs great...no leaks, etc...not overheating. i removed belt and if I turn waterpump by hand it makes a slight squeak.!?!?!? like a dry rubber maybe? Should I have used Porsche coolant and replaced all idler/accessory/tensioner pulleys as well..??wasn't sure but they turned easy..no play or grinding noise, although they did spin more freely than my new water pump & alternator pulleys. Alternator was a NAPA part that Checkered Flag Porsche dealer ordered and installed for me along with original Porsche polyrib belt. I couldn't afford to support the stealership anymore, so the following month when water pump started leaking I replaced myself with autohausz pump and filled system with peak 50/50 phosphate free /silicate free formula coolant -as this was recommended to me... is this the cause of my squeak? I hear a belt type noise while driving like a squeak/squeal/slipping belt?..it goes away when clutch is in, or in neutral , but if I rev then I can hear it.....please help..could my new water pump be going after only 2 months?..what caused it & how can I prevent this in the future?..should I replace pump now...and/or other pulleys?? since I know water pump squeaks when turned by hand..bearings still tight..no grinding etc..no play that I can feel on pulley..no leaks...what should I do..I'm pulling my hair out.!!! I'm at my wit's end. Dylan 99 carrera 70,xxx miles
  19. My '99 carrera has 70,000mi. Just recently replaced alternator, water pump and polyrib belt. Now hearing some belt noise at the rear...the idler pulleys and tensioner and accessory pulleys don't have significant play although their bearings are not as tight as the water pump and alternator..not sure if thats within spec even or not...should they be real tight too. I noticed too however that if i turn water pump by hand it makes a slight squeak kind of noise...its brand new German part...bearing feels tight and good..no play..no leaks ..car runs like a champ...belt noise is worse when i rev the engine.... I don't know what to do..really don't feel like changing the water pump if there is no other fix..big job when u don't have anyone to help u...please help. Thanks Dylan.
