dgeatdg
About dgeatdg
    2001 996 carrera4 cab
    74 930 turbo; 74?914
dgeatdg's Achievements
  1. I have a 2001 996cab4. The alarm goes off w/ no reason, usually about 4-7 hours after the alarm is set. Any ideas?
  2. There is an outfit called Wheel Enhancements (jujst google that nme) that knbow more a bout Porsche Wheel/Spacers etc. than the dealer. Check them out for answers to your tire and wheel questions.
  3. You can buy most thimgs at www.ebay.com. Read the ads carefully, and make sure you check the seller's feedback. Eli
  4. Well you'll need the wiring. BUt no matter how far you get, you'll be stuck w/ a system that is no longer supported w/ updates. All in all, you're better off buying aan avn 5435, or some other 2 din unit.
  5. 2001 have the old style hearlights. 2002 have the "Turbo" style headlight. So to use the 2002 bumper you need new fenders, headlights, etc. The are sources for a turbo look bumper for a 2001 or earlier car, but most are fiberglass rather than polyurethane. Thanks for the info.
  6. i want to replace my 2001 996 cab4 front bumper w/ a a 2002 turbo bumper. both bumpers are oem. will this work w/o modifications? thank you
  7. does anyome know where the factory amp is located on a 2001 996 cab 4? thank you
  8. Just sold an 01 nav system complete w/ cd changer, etc. they have no more updates for these models, so you're probaly better off w/ an aftermarket. the 02 and later have fiber optic connections which cannot be retrofitted w/o considerable headaches.
  9. I don't know if I can reply to my own topic, but I found a hinge repair kit for 996 whioch will fix this problem. The reapir kit part number is 996 552 960 01 if you need it.
  10. I just replaced my black console in my 996 for a carbon fiber one from a 2005 Turbo. The old glove box door is supposed to go through a couple of eyelets on the console which holds the back of the door at the hinge point. The new console does not have these eyelets so the pivot point is not properly attached. Does anyone know if there was a change in the glove box hionge design for 2005? If so,m is there a new glove box door especialy for 2005? Thanks for the info. Eli
  11. How do you remove the gauges from a 2001 996. Thanks for ny info. Eli
  12. Does anyone know where I can get console removal instructions for a 2001 996. Have a tiptronic, so the handle must be removed first. Thanks.
  13. How can you tell the differnec betwen the PCM1 and 2.
  14. Ok I bought a 2001 996 carrera4 cab. Ebay item #4574712440. I also bought a nav system from a 2000 996 ebay item #8001975202. Need to know if this can be installed w/o modifications. I do have the BOSE system. Is this going to be a hassle? Anyone in san diego that can do this? Really need to know before I start. Eli
