Attila34
Everything posted by Attila34
  1. Hello, does anyone know if I can replace the PCM 2.1 with 3.0? Must be encoded by the dealer? Modifications are needed? thanks
  2. Solved! Was the electric plug connection under the cover for the cowl panel unplugged. Thanks Loren
  3. Thanks for the quick reply, but I think that is the thelepone antenna, not the GPS. I'm wrong? Let me know. thanks again
  4. Help, please Where is Located the GPS antenna (not the ones embedded in front glass)? Today I changed the front window and now my PCM does not find the GPS location. All the terminals of the antennas embedded in glass have been connected. In the information menu reads 0 Satellites 0G gps. Any suggestion? Thanks to all
  5. I have the latest europe DVD. PM to me or mail to:airdark.e chiocciola gmail.com
  6. Hi, my Cayman S 2006 have this option code. Where is the switch and how I can rearm it? Thanks in advance to all.
  7. Hi, my Cayman S 2006 have this option code. Where is the switch and how I can rearm it? Thanks in advance
  8. My navigation system have no Target, but is entered. All works OK for you or have same problems?
  9. I look at my pcm tomorrow and let you know I'm Italian too Ciao!
  10. I don't think it uses 3.0 pcm.It's a my 2006 Cayman S,so it should be a 2.1
  11. From Durametric Technical Support: " Troubleshooting tips for Porsche Boxster (987), Cayman, and 911 (997) Here is a list of the most common problems and solutions specifically for the Porsche Boxster (987), Cayman, and 911 (997) Service Reminder Be sure there are no fault codes in the engine, instrument cluster, ABS, or airbag units. Durametric version must be 5.0.8.0 or higher. If the instrument cluster does not reset automatically when resetting the service reminder, remove the instrument cluster fuse for ten seconds with the key out before replacing the fuse." It is not entirely true, I used V.3.0.15 and a clone cable , but the procedure works.
  12. Unfortunately I have already reinstalled the console. It is a little box about 6x6 cm and thickness 1 cm, black plastic made.
  13. The other day, while I mounted the multimedia interface for ipod,under the central console, near the handbrake (in the inner of the panel),I noticed a controller with a connector but no cable attached.What is it?
  14. Yes,I think it is as you say.Thanks
  15. Found this on Durametric V5 software instructions: Common Problems and Solutions Cannot reset the instrument cluster on 997, Cayman, Boxster (987) Sometimes the instrument cluster does not accept the reset command. To clear the instrument cluster remove the fuse for the instrument cluster after using the software to reset the reminder. Simply removing the fuse will not clear the service reminder; it will only reset the instrument cluster. What does this mean? If I remove the fuse what happens? Thanks
  16. Thanks to Loren I have installed the kit, and it works fine. Only a problem: don't charge my ipod touch 2g and not even ipod nano 6g. The kit is provided with ipod cable adapter nr. 99761247100, but Porsche have also 99761247101 and....02. What are the difference? I need one of the last? Thanks to all
  17. I resign myself....Will buy a durametric or find a good mechanic. thanks
  18. Hi, recently I have personally changed the oil, filters and spark plugs on my '06 Cayman S. Today, a message appeared: "Service within 30 days ... " Is there any way to manually delete the message without the use of a tester? thanks
  19. Thanks Loren, I'll go to donate
  20. Hi, I just bought on ebay and I have the assembly instructions for the Porsche Multimedia Interface . Anyone have this: "Operating Instructions Multimedia Interface" 997.044.901.74 Or someone can explain me how to use it on a PCM 2.1 when fitted? Thanks in advance
  21. Thanks a lot!
  22. Hi, I have to replace the battery in my Cayman S in 2006. Someone able to explain the recovery procedures to be performed after the replacement? thanks
  23. It will be part number specific to your VIN. I suggest you verify with your OPC/Dealer. Thanks
