stevie s
About stevie s
    Concord, CA
    2000 MB ML430
    2001 MB E320
    1969 MB 280SL
    2005 Porsche Cayenne Turbo
    1990 Lexus LS 400
    2000 Lexus LS 400
    2001 Lexus GS 300
stevie s's Achievements
  1. Thanks Richard. That is probably what occurred.
  2. Thanks JFP! I checked my wheels and I have the rubber stems as I expected. It makes sense that the new instrument cluster may not have the option included. Just scratching my head why it would have been included in the original cluster if the option was not part of the package. A Friday car maybe ;-)
  3. My car is an o5 CTT. I am the second owner. I had my instrument cluster replaced because the turn signal clicking sound and the door alarms were inaudible. I should have done the due diligence checks when I was given possession of the vehicle but did not. Now, almost a year later, as I cycled through the settings, I noticed that the TPMS option that I used to come across when changing the settings was now gone. Now I know my car does not have TPMS, but I used to see a graphic with the 4 wheels and dashes next to each wheel, for tire pressure I assume. It would not do anything but it was there. I also seem to recall that there was another menu tree that I could access prior to the replacement but can't be sure what it included. I am not sure if this is an issue or if I have been short changed some options now. Any ideas why I would see a TPMS graphic if I did not have TPMS in the first place? I have gone through the codes in the trunk and it does not mention TPMS as an option when it was purchased. I hope I am not losing my mind.
  4. Many thanks Vivicary! This site is truly great. Folks reading this: Everyone should donate as requested in the banner. The time and expense saved by all the tips and DIY's are worth every penny donated.
  5. Hello forum, I was tinkering around my 05 CTT the other night and removed the panel that allows access to the brake fluid reservoir and I saw this component wedged under some wiring. It wasn't plugged into anything and was just floating free. I looked around but couldn't figure out where it came from. There are a couple of detents that make me think it is keyed to be twisted into an opening somethere. Does anyone know what this is and what it does? The car runs fine. Looks like a sensor of some kind. Thanks all in advance.
  6. hahnmgh63, wish I had known but when I saw coolant leaking, I thought it was the coolant pipes and figured that I needed to get it to the shop right away. I try to DIY as much as I can.
  7. Forgot to mention that I have an '05 Cayenne Turbo with 67K miles.
  8. I have also experienced this over the weekend. Took it to Porsche in Walnut Creek and am being charged $670 to replace.
  9. Hi all, I went through this ordeal this weekend and wanted to clarify the procedure - when you remove the U shaped PCM trim, the AC control unit clips are not visible. There are two square holes on either side of the unit right beside the fan speed rocker switches. The clips are recessed inside and you will need to shine a light in there to see them. I used two small screwdrivers to push in the clips and wiggle/walk the unit out until the clips unlock. Once unlocked, the unit slides out easily. Once out, the ashtray is held in by two screws and comes out easily. Note: You will have to move the shift lever to the Drive position for ease of ashtray and AC control unit removal.
  10. Hi Tim, They were Falken tires and my estimation is that they had about 15 - 20 k on them. I wasn't the original owner and these were the tires the car came with when I purchased at 66K.
  11. I finally found the issue. The passenger side rear tire tread had separated from the ply so when parked, the tire seemd normal but at speed it made the noise. A dangerous situation no doubt but caught it in time. 4 new tires and a 4 wheel alignment and she runs like a dream.
  12. Thanks all for the warm fuzzies :-) Forewarned is forearmed
  13. Haha, I tried saying it it and I do actually hear that sound, but only from a dead stop until I get to about 5mph.
  14. I have the same issue. I am wondering if this is a symptom of a differential in need of service. Maybe a diff. oil change?
  15. Thank you both. I will try rotating the tires. As to the change in noise based on the load levels, I do not hear a change. I was driving slow this afternoon trying to gat a good idea of where this is coming from and I am starting to feel that it could be the differential. I hear the sound start up when starting to move and I feel a slight vibration in the pedals. Could low fluid levels in the front differential cause this? To describe the sound another way it is a whirring sound that starts low and increases with speed. Steve
