loday22
    997S
loday22's Achievements
  1. Is the GT3 roll bar the same as the RS? Part # will be appreciated. Thanks/David
  2. My first baby will be due next Janurary. I'm just wondering if it is possible to add rear seats to my 997 GT3 or maybe adding belts to hold the baby seat at the rear? This is a car I enjoy over the weekend, and with a new born on the way, I will not be able to take my wife and baby out at the same time. Any guidance will be appreciated. Thanks.
  3. The fan on my aerokit only comes on when it is suppose to.
  4. Does anyone know if the -20mm euro springs would work on PASM cars. If so what are the part numbers for these euro springs? I have these H&R's for PASM, but it is way too low for the factory aerokit. Thanks.
  5. Checked cables they are all secure, is there a switch to turn the trunk lid light on/off? Thanks.
  6. Dealer charged me $135 to deactive the warning light, but the trunk lamp does not seem to turn on when the trunk is open. is there any way to find out if there is power to the lamp and the fan? This is frustrating.
  7. Aerokit was installed by a bodyshop. I'm very sure they installed the new wiring harness because I was there during the installation. Earlier I pulled out the fuse for the spoiler and it was fine, but now the problem is worst; PSM and PASM failure lights both came on. This is very frustrating.
  8. Question for Loren: My car had installed the factory aerokit recently, and it was the first time I drove my car pass 75mph last evening. Surprisingly the malfuntion light of the rear wing came on. I then headed home and checked to see if the new bypass wire was securely plugged in and it was. As I opened up the engine lid, I found out that the little lamp was not even turned on while the lid was opened. Would this be a fuse problem? It looks so simple, and there is only one plug to get the electricity. Any help will be appreciated.
  9. Thank you Loren, that was great. I hope they're the same.
  10. Anybody have the Carrera S emblem placement diagram for the 997 aerokit? Thanks.
  11. My bodyshop cannot locate the color code for my 997S, does anyone have reference to this in Carerra white? Your help is appreciated. Thank you.
  12. I heard that there are 2 part numbers for the 997 aerokit, one with xenon head lamps and one without? Is this true?
