j_beede
Everything posted by j_beede
  1. Not to mention the problems that boxer engines have with ring wear on the bottom side of the pistons due to the force of gravity Well...Here you are...It is normal.....Right from the Owner's Manual for 997's, And it is the same for 996 as well: Let me make sure I have this right... 24 quarts of oil added between oil changes is considered "normal" per the owner's manual... You are okay with that?
  2. Well...Here you are...It is normal.....Right from the Owner's Manual for 997's, And it is the same for 996 as well: Disagree. "Up to" 1.5 liters per megameter is legal language to protect the manufacturer. Two quarts of oil to make a round trip from SF to LA? May as well replace those fouled plugs too!
  3. 1 quart per 1000 km sounds excessive, I would say that is a problem. I see several manufacturers claiming that 1 quart per 1000 miles is "normal" when their cars typically use 1 quart per 5,000 miles. I suspect they are simply trying to avoid warranty work for those outliers that consume oil. Comparing the oil consumption of a 300 HP, 7000 RPM engine designed to last 60,000 miles to an 18,000 RPM V8 designed to last 300-400 miles is unreasonable in my opinion.
  4. I've seen this as a telltale indicator of a failing battery cell. Is there any difference in window speed with the engine running versus off?
  5. Given the inadequate lubrication that the m96 IMSB is subjected to, I think you were wise to replace your bearing. Lucky for you that your engine was eligible for the retrofit--not all are. Did your independent mechanic do some expectation setting with you regarding the replacement bearing and its lubrication?
  6. If your car is eligible for the LN Eng retrofit I would do it at your next clutch change. Keep in mind that the retrofit is not a cure for the inadequate lubrication that I suspect contributes to IMS bearing failure. The retrofit simply allows the bearing to be replaced without requiring engine R&R and full tear down--major savings there. Unfortunately, 996 with later model m96 or engines replaced in q4-05 or later may not be candidates for the retrofit. This is the 13mm versus 22mm IMS nut topic that you have probably heard about.
  7. I answered this same question for you two days ago. What's the deal? Here is the same answer again. The engine code is on the driver side of the block just below the #3 cylinder exhaust header. I find the code hard to read without putting the car on a lift. I had success using a digital camera to photograph the code and was able to read it that way. If your engine has "AT" in the code like this: M96/04AT66***** it means your engine was replaced. Some people view this as a plus, but it usually means that you have an IMS bearing that cannot be replaced without a full engine tear down. This probably means no LN Engineering retrofit option for example.
  8. The engine code is on the driver side of the block just below the #3 cylinder exhaust header. I find the code hard to read without putting the car on a lift. I had success using a digital camera to photograph the code and was able to read it that way. If your engine has "AT" in the code like this: M96/04AT66***** it means your engine was replaced. Some people view this as a plus, but it usually means that you have an IMS bearing that cannot be replaced without a full engine tear down. This probably means no LN Engineering retrofit option for example.
  9. FYI: Sunoco 110 racing fuel is leaded too.
  10. Repeat: Reman engine probably means no IMSB retrofit for your car.
  11. I can't imagine a more impressive $20,000 used car than a MY99 996! Great looking and too much fun to drive. Just keep in mind that these cars cost $60,000 to $80,000 when new and the prices for parts and service do not scale with the car's resale value. Has the engine been replaced? It was not uncommon for MY99/00 996s to have their engines replaced. The issue with the reman engines is that they are often not candidates for the LN Eng IMSB retrofit--if you care about such things.
  12. Since the factory bearing can fail below 20,000 miles or survive beyond 100,000 miles I suspect we will find out at some point that the bearing (sealed or open race) is not the true culprit. I think others have commented on eccentricity in the IM shaft itself as the likely root cause. The LNE external retrofit doesn't address the shaft itself. I believe that Flat6 offers a more extensive retrofit if the IMS is sent to them for re-machining. I assume they take care of IMS eccentricity as part of that process.
  13. $6,000-8,000 for a 996 with a blown motor sounds optimistic--unless it has a remarkable set of wheels, fresh tires and full fatory aero kit.
  14. As noted... The "AT" in the engine code indicates a Porsche remanufactured engine. Yours is a 3.4L and appears to have the newer--and non-replaceable--IMSB with 22mm center nut. If that is so, there is no LN Eng retrofit opportunity for this engine per J. Raby. Many MY99/00/01 owners are pleased to find out that they have a newer replacement engine. Personally, I have avoided 996s with the M96/**AT engines because of the non-serviceable IMSB.
  15. Pushing the car to 10 MPH then dumping the clutch after the engine seized? Sounds pretty barbaric. Were you hoping that the engine would start and your friend would drive away happily ever after? Disappointing to hear of this given the effort that was put in. I had been "on your side" up until then.
  16. Well, well. Amazing. I can't imagine what the end of the shaft must look like. Next step... order an IMS Guardian :)
  17. Have you been to Mesa Verde in Cortez, CO? If you go to North Rim of the Grand Canyon, Mesa Verde is worth a stop.
  18. FYI: The last 996 engine I checked read: M96/04AT66Y6xxxx. My understanding is that the "AT" indicates a reman engine.
  19. I believe it will be some sort of variation of a magnet positioned so that it accumulates ferrous metal particles in the oil between two electrodes--thus closing a circuit that makes the buzzer/light turn on. For the price he is charging I am sure that it will be more than that. I think it may be a while before it is available in volume as he seems to still be making changes to the design.
  20. You probably know that there are multiple versions of the IMSB in m96 engines. The earlier IMSB is a candidate for IMS retrofit, it has a 13mm center nut. The later m96 such as those used as replacement engines in 996s may have the later IMSB with 22mm center nut which is not a candidate for the LN Eng IMS retrofit. Unfortunately, the transmission must be dropped to determine which IMSB you have. Has the engine been replaced in the 911 that you are considering? No the engine has not been replaced. Can you tell by the block number? Yes you can. A "reman" engine will have the letters "AT" in the engine code something like... M96/04ATxxxxxx
  21. An 8.5mm camera probe is only a bit larger in diameter than a pencil. It should fit!
  22. You probably know that there are multiple versions of the IMSB in m96 engines. The earlier IMSB is a candidate for IMS retrofit, it has a 13mm center nut. The later m96 such as those used as replacement engines in 996s may have the later IMSB with 22mm center nut which is not a candidate for the LN Eng IMS retrofit. Unfortunately, the transmission must be dropped to determine which IMSB you have. Has the engine been replaced in the 911 that you are considering?
  23. Motor swap at 85,000 miles... sorry to hear that. Can you request an engine with a 13mm IMS bearing center nut?
  24. Loren, it's more like a very thin plastic film that is on the outside of the caliper. It had bubbled and wrinkled, and now part of the outside of the caliper looks faded and not bright red. My car was in an outdoor parking lot for about a week, and it had rained and stormed. The discs, particularly the fronts, were very dirty and sort of crusted with gunk. Normally, after washing, a coating of rust will appear on the discs, but it cleans up after first braking. this time the gunk was dried and hard and causing a grinding sound when I first drove the car and used the brakes. I drove for awhile until I could get to a station with water and sprayed water on the discs. this loosened the crap and the discs then smoothed out when I drove the car and used the brakes. I dont think this would have overheated the calipers. the plastic film is like the protectors on new appliances that protects from scratches and peels off easily once you get home. Ever hear of anything like this on C4S or turbo calipers? Cheers, jl That would have to be some pretty high temperature plastic film to put up with caliper temperatures. Perhaps someone clear coated your calipers? What sort of material would remain stuck to a rotor after braking--yet rinses off with water? Odd. What did it look like?
  25. ...almost forgot... be sure to take along one of those Harbor Freight 20% off coupons that you find in Autoweek etc. That makes it $192!
