boxster-s-dk
Everything posted by boxster-s-dk
  1. Very very nice...perfect wheels and GT3 skirt Welcome Regards Stefan Denmark
  2. Sounds like coil pack or maybe check camshaft deviation, worst case might be IMS bearing that is on the way out, so it turns on engine fault?? Your oil pressure is still very low, when idle hot. I have 2,2 bar hot, and 4,5 when cold...I use Millers Nanodrive 10w-50 (but only 2 years old engine) Good luck Stefan Denmark
  3. Hey great for you...what has been done to the engine? It should be great weather here in Copenhagen this weekend;-))
  4. Is it a 3.4 or 3.6.? Hope you are right, about taking the car to germany...but I think you are... They must know a lot more about these engines, and how to fix them right, than MLA. I have only nice to say about MLA Copenhagen, but you pay the price;-)) Good luck, and maybe I will see you on the road, here in CPH;-) Let us know further more about how it goes... Regards Stefan Dk
  5. Any news fra MLA Copenhagen?
  6. Does not sound good, sounds like pistons might pumping air in your coolant. Look at your coolant fluid, it must be clear and light red, otherwise you have a big problem. (Nice to see another from Copenhagen) Held og lykke Stefan Copenhagen
  7. Change it anyway, then you will have a peace in mind ;-) I would...
  8. The car sounds nice, but I would not buy a 996 with an engine fault to start with, no matter what. Get the seller to fix it, before you buy it... Best of luck Stefan Dk
  9. Uhh that's easy...Millers Nanodrive 5w-40;-))
  10. Just don't ask about IMS or bore scoring;-)) Anything else...anything;-)))
  11. Thanks but I think prefer a new one;-) But ofcourse I will sell the old one...
  12. Will the OEM 997 shifter fit my 996 short shifter...I dont want short shifter anymore? If so, does anybody got a partnumber for a complete oem 997 kit? Regards
  13. That is a rebuild from Porsche...like mine;-))
  14. Congrats ;-) Nice rideMaybe check the fuses, weird with these electric problem.RegardsStefan
  15. Maybe the user manual can help...? I know my 2003 has a +terminal at the fusebox, that you can pull put about 3cm, so it can be charged. Regards
  16. If I lived in Miami, I would choose http://www.mobil1.dk/motorolier/peak-life-5w-50.aspx
  17. I believe it is their "raceoil"...;-) Should also gain a little extra horsepower, because of nano tech, according to another website....but I dont know about that;-)) Thank you very much Regards Stefan Dk
  18. So it looks good? Thanks Regards Stefan
  19. I have found this, but I dont know what to look for... http://www.millersoils.co.uk/automotive/tds-automotive.asp?prodsegmentID=929&sector=Motorsport Regards Stefan
