ReyGabriel
Everything posted by ReyGabriel
  1. Every time i turned on my AC...there is a sound thats like the fan is touching something... i wanted to take a look at the AC blower...where do you think i have to start to see the AC Fan...thanks
  2. thanks Maurice that was a good explanation...
  3. thanks cassiebox...i will try your suggestions...its should not really be that hard to find the trouble..
  4. I have tried to replace the fuse of my cigarette lighter but when i put my cell charger, its busted again..is the charger shorted coz the last time i pulled out the charger, its seems hot...now i dont want to try my Navi coz it may burn it too...any advice from my good boxster friends...thanks
  5. thanks guys for helping me on that...really appreciate it...its now working...i didnt realiazed that i wasnt doing the requirement prior to opening up the top...i forgot i have to keep the engine running since its the engine that drives the gear...ha ha ha..plus i have to get the handbrake engage...i am getting old..i was embarrassed when i could not get that thing down and the girl besides me laugh me off and said i have to get it fixed...i get stupid sometimes...sign of old age...ha ha ha...thanks guys for your good advice...i will remember you names...
  6. I tried to look at my engine last week and tried to open up the top by pressing the button and removed all the covers ...but now i was trying to open the roof...the button seem to be not working...did i bust the fuse? I dont know if i have put back the hanging canvass cover with two cables...if not does it have an effect on the operation of the roof? I will try to look at the fuse if its is burned... I'll appreciate your opinion...thanks
  7. I tried to look at my engine last week and tried to open up the top by pressing the button and removed all the covers ...but now i was trying to open the roof...the button seem to be not working...did i bust the fuse? I dont know if i have put back the hanging canvass cover with two cables...if not does it have an effect on the operation of the roof? I will try to look at the fuse if its is burned... I'll appreciate your opinion...thanks
  8. tnx logray...i guess mine is just normal...when its just been driven...there is no smoke...it only happens once in a while like once while in week..i can sleep well..
  9. yes its white smoke...
  10. just about a few seconds...then its gone...and its not always there are just some days like once a week.
  11. I am just wondering why there are times when i start my 986 smokes come out...is this common to 986 or i may need to replace the valve seals...
  12. thanks harrycrb...i appreciate it..
  13. tnx mcmike...that was a good explanation i appreciate it...for logray..i am a new member and i have not seen all other topics yet...I dont need that kind of rude and hotshot reply..be more friendly please...you were once a new member..thanks...
  14. as i drive my boxster 99 in a hot days...my water temp gauge goes up from 180F to about 220F a little bit off the center..Is this normal on all boxster..I live in florida which is a sun city... but i think that it is not normal for water temp to rise to 220F for a traffic and a sunny day...any suggestions on how to keep the temp gauge pointer from rising..is dont want to jump cleaning the radiator right away..i want to see first if there may be other reasons..or if that is normal for bosxter since its a high compression engine..1:11 compression ratio..
  15. check again at broad daylight your coolant level...its "hard" to see the level...the max should only be about half an inch to the top...if you can see the arrow pointing upward as the max..then see the line.....if this dont work. ...you have to check the temp sensor underneath the coolant container..
  16. Hi Guys...Happy to be a member of this site...Thanks a lot...
  17. Your mechanic can be trusted because he did not point out to you a big job... he may be right...the belt accumulate dirt so much that over time...and its with oil, dust and all types of contaminant that are up in the air as you drive this hardens up the belts...the cheapest way is to clean the belt is with soap and water using a clean rug. You dont need to take it off the engine..You can reach it out as you scrub it back and forth...If this dont work try a pulley belt cleaner in spray can.. Its better to start with the easiest and the cheapest suspected trouble than be dreaded by all those slipping clutch, release bearing and all....believe me trust your mechanic.... the squeling sound you hear is usually when its raining and early in the morning when the belt has moist in it...When it squels the belt gets hot and dries up quick and goes to grips the pulley back again...
