DougD
About DougD
    2005 Turbo Cab S
    1969 Jag E-Type, Datsun 280z, '99 993 cab, '01 996 cab
DougD's Achievements
  1. Dension now makes a compatable ipod adapter for CDR22, maybe CDR23 too http://www.dension.com/oem1.php
  2. I'm the proud owner of a '05 Turbo S Cab. I have 2k miles on the car and have noticed a disturbing anomaly with my oil pressure gauge. Between 2 and 3 thousand RPM's the pressure will drop from approximately 4 to 3 bar. The spike is sudden almost as if the oil pickup has starved for an instant. As soon as you bring the rev's above 3k the pressure pins at 5 bar and stays there. The oil level has been 1 qt low to full when this happens.I'd like to find our if anyone has notice this potential problem. Thanks for any input
  3. Yes, thank you I would still like them. What format are they in?
  4. I pulled the CD holder out and can see an "unattached" wire connector with 4 wires. I guess this could be for many connections? <{POST_SNAPBACK}> Have a look at this thread. <{POST_SNAPBACK}> Thanks Loren that tread did the trick for the mute. From what I read, I guess there is no "input" for the voice audio? I might try to hook right up to a door speaker. It should lose it's signal when the mute kicks in. Too risky?
  5. I pulled the CD holder out and can see an "unattached" wire connector with 4 wires. I guess this could be for many connections?
  6. Hi Loren, Where would I find the options list? This code does not appear on my Window Sticker. Is it on a decal on car? <{POST_SNAPBACK}> Have a look into the service book, Your original hood might have been replaced <{POST_SNAPBACK}> No luck on the service book, it is completely bare. Would they let it leave factory without this? Maybe hood got damaged during ocean freight? Dealer claims that no hood was replaced. Without this info, what are my options as far as wiring possibilities? <{POST_SNAPBACK}> Hey I did find this sticker in bag of Misc. parts in trunk? Any help? Sticker_codes.pdf
  7. Hi Loren, Where would I find the options list? This code does not appear on my Window Sticker. Is it on a decal on car? <{POST_SNAPBACK}> Have a look into the service book, Your original hood might have been replaced <{POST_SNAPBACK}> No luck on the service book, it is completely bare. Would they let it leave factory without this? Maybe hood got damaged during ocean freight? Dealer claims that no hood was replaced. Without this info, what are my options as far as wiring possibilities?
  8. No paper work under the hood as far as I can see.
  9. Hi Loren, Where would I find the options list? This code does not appear on my Window Sticker. Is it on a decal on car?
  10. To start with, sorry for what seems a repetitive question on this topic. I've tried to hunt down this answer but found broken links to old strings. I would like to get a wiring diagram or advice on what pins/wires to connect a blue tooth phone kit's mute output wire/pins and voice audio input wire/pins on a 2005 Turbo Cab PCM. I would like to use cars speakers to hear phone conversation as well as mute stereo when incoming calls ring. I think this info used to be in the Owner's manual for a '02 Cab I had, but is no longer included. Any help or advice is appreciated!
