BAD124
Everything posted by BAD124
  1. Yes, and to do both lights (14 Bulbs) is about $85. Which is about the same price as an entire interior set. Think I might try the LED strip route
  2. That was my first thought too, but to do both strips (wing light, top light) its about $85. Creekman - did you use the available adapter or just solder to strip directly?
  3. I like that idea. Where did you get the LED strip from ?
  4. I think you answered your own question..if you only ever see a dusting at most, all seasons and proper driving should be enough. A Blizzak would certainly work, but sounds like over kill in your situation. These might be a good option - http://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=ExtremeContact+DWS
  5. JFP, Thanks :cheers:
  6. Uwon, did you ever remove and check the oil level via the plug (non allen head) near the shifter cables? If so was it near the plug? I filled mine until it spilled out of the #1 hole on post #61 of your link and that was about 2.75L
  7. Listed as 3L capacity. Mine took about 2.75, so it seems to vary. Fill till it comes out. I dont think there is a risk of overfilling in this case
  8. Wow nice, what the model and year ? Mine: 03 C4s 98,000 Bought March 1st 2013 with 87,000 = avg 1375mi/month :drive:
  9. LI - I had the same issue. Try putting some oil on a q-tip and running it around both the rubber seal and the other half where it connects. This should allow it to snap in
  10. Close, but actually a Mercedes 124 (E Class from 86-94) :drive:
  11. Due to the different resistance of the bulbs, I believe this could have an effect on the cruise control. I think the solution would be to add a resistor, but maybe someone can verify
  12. Wow, if I was in Michigan I would be all over this. Is this going to be a buyers guide of sorts?
  13. Hi all, I am looking for some buyers guide info on the Mk1 997 GT3's. The links above seem to have expired. Does anyone have the documents they could post up ? It would be most appreciated. Thanks in advance Brett
