seano3625
Everything posted by seano3625
  1. erm....no,the car is not under warranty....the car is 'recond' car.....in my country,the dealer don't want to repair this type of car which is not import by them.....somemore need to pay the expensive labour.....so,can someone please help me find out the information.....thanks....
  2. sorry loren,the car model is 997 carrera 4s (pdk) year 2010....or you need the vin number???please help me....thanks.... :thumbup:
  3. sorry loren that make you confuse...ya,i means is cam timing....do you have any information about that and what special tools that we need???thanks....
  4. thank loren for reply.....why i can't see any price in my account???is't a network connection problem or other???? :huh: loren,do you have the information that how to set the engine timing for the 997 2nd generation....and the firing order to this engine.....the car is 997 pdk carrera 4s....thanks.... :notworthy:
  5. thank loren for reply.....why i can't see any price in my account???is't a network connection problem or other????<br /> loren,do you have the information that how to set the engine timing for the 997 2nd generation....and the firing order to this engine.....the car is 997 pdk carrera 4s....thanks.... :notworthy:
  6. loren,how to add money to my account???i can't see the 'order' button in there.... :huh: and do you have the information???can you help me???i really need a help...thanks.... :notworthy:
  7. thank for logray...i have try your link and create a account,but the problem now is i can't purchase the document which is no 'order' button to let me order.....do you know why????
  8. erm....actually the car that i repair is 'recond' car which is the dealer also don't want to repair....and if want let the dealer to repair it,we must pay a lot of money....sorry for my poor english....
  9. erm.....actually i'm the mechanic who repair this car..... :huh: i'm not working on the dealer,so i can't get the information,and need to fix it by myself....do you all have the information about this car???please help me.... :notworthy:
  10. sorry ya....the car is 997 carrera 4s and year 2010...thanks... :notworthy:
  11. hai....do anybody know what does this fault code(P0018 crankshaft position vis-a-vis intake camshaft,bank 2) means??what should i do???=(it's the engine timing out????does anybody have manual that how to readjust the timing.......please help me.....thanks.....
  12. the fault code is 'p1221 sensor for airbag(driver's side,front)
  13. loren,the piwis tester will tell us where is the sensor location is???i have use the piwis tester to diagnose and the the 'sensor for airbag(driver's side,front)',this is the code i get and i don't where the sensor location is.....i have found some info say that the sensor is under the seat....but i can't get it.....should u know where the sensor is????please help....thankss....=)
  14. hallo everybody.....i have a airbag warning light on and the fault is 'sensor for airbag(driver's side,front)"....anybody have this experienced????does anyone know where the sensor is????it's the sensor under the seat????i have remove the seat and see but i can't get it????any idea???please help me...thanks....=)
  15. it's a cayman S year 2006.....and what mean of TSB??? :blush:
  16. thanks for reply loren the fault code is 'p800b-driver head air bag above upper limit'....what can i do???i have try clean the all connector but it not work.....please help me..... :huh:
  17. halo....can someone tell me where the cayman driver's head air bag????there is no airbag on 'A' pillar...so where is it????please help me....thanks....
  18. hai....does anyone here have a experienced to rebuild the 964's engine??i have some problem while i'm rebuild the engine...my problem is my engine got oil leak on the camshaft housing....does anyone here have a exerienced about it???and any suggestion to solve it???thanks a lot....=)
  19. thank for reply loren....is engine timing...
  20. Do you mind to share the information with me??=) i have check the transmission oil level and plug in the piwis,then i get the 'P0841 pressure sensor 1 implausible value', i don't the document to describe what does this fault code means,and what are need to do....so any idea??? and one more thing,do you know how to adapt the turbo boost pressure adjuster???thank.... :lol: You need to use the PIWIS Fault Finding program. ya loren....i have use the piwis tester to diagnosthe car and get the code that i mantion before....do you know what does the code mean???thank...
  21. halo....does anybody have experienced to set to engine timing of 997 carrera S???? thanks... i'm not sure the timing that i set is correct or not.... :unsure:
  22. Do you mind to share the information with me??=) i have check the transmission oil level and plug in the piwis,then i get the 'P0841 pressure sensor 1 implausible value', i don't the document to describe what does this fault code means,and what are need to do....so any idea??? and one more thing,do you know how to adapt the turbo boost pressure adjuster???thank.... :lol:
  23. loren,thanks for reply... do you have any information about pdk??
