ChrisTsangaris
Everything posted by ChrisTsangaris
  1. yup tried it initially the dash airbag light would go on and off and also the passenger airbag light would go and off , now it just stays permanently on
  2. ok sounds good, ill have them change it to see if it improves , hopefully nothing is damaged, it behaves normal only in regular driving, it only starts acting weird when i get on the gas hard then it never changes to the next gear
  3. I checked with Porsche they said regular intervals are 997 - 120,000 miles or 12 years
  4. 63000, still on the original trans fluid
  5. Hi, So my 06 911 S started acting weird. Whenever i get on the gas the car has full power but then as soon as i reach the revlimiter the tiptronic transmission is not shifting to the next gear and just bounces off just below the red line , the gear wont change even if i let the car slow down, the gear only changes if after i ease up off the gas and i press on the tiptronic button. This behavior occurs both in automatic and in manual (tiptronic mode), no errors on the dash thanks
  6. Hi everyone , I recently had my airbag light go on all of a sudden without any accidents occurring , it happened after I moved the passenger seat backwards,I took the car to a porsche mechanic but not at the dealership and got the following errors 8057 was control module , read out fault memory c141 communication pcm 2.1 8c09 rear left sensor faulty 8d09 rear right sensor faulty 8a09 front left sensor faulty 8b09 front right sensor faulty they tried to say that it had to do with the ground of my aftermarket radio which I’ve had for 6 months with no errors any ideas??? thanks
