dchesrown
Everything posted by dchesrown
  1. What is the cost of the chip?
  2. I am in Central OHIO. I guess I can try the local Porsche store, unless someone has a suggestion. David
  3. Can you remove the ugly front bumper extensions(the two abs plastic bumpers) without leaving a hole? If so how do I do it. Thanks David
  4. I am getting the rear spoiler failure light. Spoler does not go up. What should I do? Thanks David Under what conditions? What model year car? Standard, or aftermarket spoiler? 2001 996 turbo, total stock car, no mods, when I hit the spoiler button or drive above 70 mph. It does not go up. I get the light. Thanks David
  5. I am getting the rear spoiler failure light. Spoler does not go up. What should I do? Thanks David
  6. Great, just 16000 miles on it. My warranty expires this December, I hope it does not fail again.
  7. I had my 2002 996 in for an oil change and the dealer replaced the crank seal and also put on new flywheel bolts. Is thes the RMS problem I read about just under a different name? Thanks David (edit - removed ALL CAPS - Loren)
