roanne4
Everything posted by roanne4
  1. Nobody tries both ? I will try a 295 hp in April. Comparison with my 280 hp then. 300 hp is not for 2007.
  2. Just back from Porsche dealer, they noticed the noise. after a serious lubrification of the entire mecanism of the roof, the noise disappears on driver side but still slightly present on passenger side but very low. it seems that, at the fabrication this lubrification was too low. problem solved ( for the moment). regards roger
  3. I agree with that. I have a visit on 26th at the Porsche center to check. I'll keep you informed merry X'mas. roger
  4. Hi since i have 5000 kms we can ear a cracking noise coming from the roof when closed , on each side appearing on bad roads. someone already know that ? solution ? many thanks best regards roger boxster S 987
  5. good idea , it was the AC drain tube unplugged many thanks roger
  6. Many thanks, I think you have found the problem , a visit to my Porsche agent is planned . best regards
  7. Yesterday a extremly rainy day , what a surprise the floor on passenger side is wet, i remove half a liter of clean water ( not cooling ) , each rain the water is coming back . any idea ?? my bowster is fully new ( one week). many thanks best regards roger
  8. the motor was hot after filling the tank I need three trials to start the engine. never happened before someone knows that ? many thanks roger boxster S jan 2002 39000 kms.
  9. Hello Yesterday I met a friend who has just received a boxster S ( may 2000 ) and he has a problem with the roof switch . In fact it seems quite stupid but the switch falled inside the dashboard when he pressed it . what could has happened ? a solution ? many thanks for your help regards roger
  10. 502 Means Uusikaupunki production center , it is an internal porsche code.
  11. I have read taht for a 3.2 l the normal slow running is 700 trs/min , for the 2.5 l what is considered as "normal" ? 750 higher ? many thanks for your help. roger
  12. many thanks Loren I have been able to mount my new white lights ...now with a new tool. regards roger
  13. I 'm looking for part number of the key to mount/ dismount the front lights written on it " KLEIN 5 mm " mine is no more hexagonal but round .... :( thanks roger
  14. I have the same charger, the light is red when charging and off when the battery is full . roger
  15. Yes many thanks best regards roger
  16. On Boxster S january 2002 , i'd like to find the part number for the textile protector of the plastic rear window . In the doc indicates that we need to put it when mounting the hardtop in winter. thank you for your help regards roger
  17. Contact your porsche dealer or try opel navigation cd .
  18. If you have 5.43 software version , it works .
  19. may be the seat heating with 2 positions
