MNBoxster
Everything posted by MNBoxster
  1. Hi, '99 TipS here too. I hate to be the one to tell you, but the indicators flashing between '4th' and 'M' are a fault indicator. This Fault Indicator has initiated the Emergency Program in the Transmission Control Unit. Straight from the Owners Manual - " If there is a fault in the Transmission or the Control Unit, the 4th-gear and Selector Lever Position display Flash altenately. To remedy the Fault, immediately consult an authorised Porsche Dealer. See also Emergency Program" Emergency Program " If there is a fault in the Transmission or the Control Unit, the 4th-gear display and Selector Lever display in the Instrument Cluster Flash alternately. Regardless of Selector Position, 4th is the only Forward Gear still available. Adapt your driving habits to the changed situation and bring your car to an Authorised Porsche Dealer for repairs. CAUTION Reverse Gear Lock Monitoring is disabled in the Emergency Running Program. Do Not select position 'R' while driving in a Forward direction. WARNING Do Not shift into 'R' while the vehicle is moving forward. Damage to the vehicle may result as well as a loss of control, if the vehicle is moving forward fast enough to cause rear wheel lock-up." Hope this helps. Happy Motoring!... Jim'99
