WhisperBlade
About WhisperBlade
    Canada
    Other
    Porsche Cayenne S 05
  • Future cars
    Porsche Cayenne Turbo S 11
WhisperBlade's Achievements
Community Answers
  1. Hello, My rear taillight has a cracked lens (chunk missing) Don't wanna pay for a new housing. Does anyone know where and if one could purchase just the lens cover? Thanks in advance. .C
  2. Hi rik, The mirror that I have is a dimmable, heated one. Would the cheap replacement glasses cut it? Thanks! .C
  3. Hello Forums, A driver in oncoming traffic swerved into my lane and rammed into my driver side mirror. The mirror bent inwards. Upon reengaging, I found that the lens had cracked, the top plastic cover had flown off and the bottom had a scratch on it. The OE Mirrors part number is - 95573104303. These are 350$. I'm not sure what my insurance deductible is but this seems outrageous for a mirror. Does anyone have a cheaper fix to this? Thanks.
  4. I have had the exact same problem with the exact same symptoms. Your CET has failed. Replace the CET. You also have air trapped in your radiator; You'll need to to vacuum your CET after your change it.
  5. I ended up having 2 of the low-pitched horns go out. I got frustrated with the process so I just unplugged the low-horn and closed the circuit. The high horn works fine now. Don't need the low anyways.
  6. I just wanted to confirm - Do I need six GALLONS of coolant? (I'm in Canada. Things are sold by the litre). In which case, I will need 11.5 Litres of Coolant + 11.5 Litres of Water? Thanks!
  7. Awesome. Very comprehensive. Thanks a lot!
  8. Mihai, Do you have any recommendations on air compressor? (The Porsche one in the truck goes to 80 but I'm not sure the hoses fit?)
  9. One more question; Does anyone know that, when using the AirLift II, what PSI is needed for coolant flush? Would the factory-equipped air compressor in the trunk suffice? Thanks!
  10. And thanks a ton Mihai. I hope anyone else researching into this will get some useful tips.
  11. No air suspension. Bleh. Looks like I'll have to jack it. :(
  12. Thanks! I appreciate it! Does anyone know if the car needs to be lifted for a full coolant flush, or can I do it off the ground? Thanks!
  13. Diagnosed as broken coolant reservoir. Does anyone have any walkthroughs or general tips on DIY replacement? Thanks!
  14. Hi everyone, Replaced the Pipes on 05S 4 years ago. Recently, car is displaying "Check Coolant level" and coolant level is dangerously low. Last top off was only 2 - 3 weeks ago. There is no visible mark below the car of any leaks when parked in garage. I parked it outside in the cold last night and got this warming again. It's raining, and I can't verify if there's a leak. Anyone know what might be the issue? 126K KMs. About 80K Miles. I've got Water Pump from Pelican parts in my shopping cart ready to order. But since I live in Canada, I want to order anything that might be the issue all in one go. Thanks! .C
