quietcoolone
Everything posted by quietcoolone
  1. Ok.. Thanks again.
  2. That is the serial as displayed on radio unless the second digit is an "S" and not a "5" WS007293. Could that be the case? Please check and advise. Thanks in advance for the help.
  3. Thank you. Unfortunately that one did no work. Is there any other code to try?
  4. Hello Loren, I recently requested to code to my original Becker radio and it worked, but unfortunately spilled soda all over the radio due a sudden braking incident. I purchase a used CR-220 Serial W5007293. Can you please help with the radio code? Thanks again.
  5. My 2000 Boxster S radio locked up after battery replacement. The dealer (50 miles away) did not want to help without taking the car in. BE4362 Y5023135 Please help. Thank you!!
  6. Hello Loren, Can you please help me find code for CDR-220 serial Y5052714? Thanks in advance
  7. thank you.. i will try to trace these wires between from boot through firewall .. Will post back when resolved.
  8. Loren, Thank you so much no other gauges are off-- the gas gauge was stuck on 1/4 but tank was almost full, -- went to gas station added about filled it up -- gauge went up to 3/4 and red warning light continue flashing. A few days later the gauge is back down to 1/4. I wanted a wire diagram to figure the function of each of the 4 wires comoing out the tank.
  9. Hi, 2005 Boxter gas gauge stop working. The tank is full but the gauge reads empty and low level light is flashing. The car was at a shop (not dealer) for DDL light install and since then these issues have surfaced. Does anyone have a gas tank wiring diagram? There is a larger gauge brown, green/black and small purple, purple/black i'm interested in tracing the wires from the boot to the interior hopping that the wire colors are the same across the grommet through the firewall. Any help is greatly appreciated.
  10. Did you install that adapter and if so can you provide some pictures of the connection, dash etc.. Thanks.
  11. Loren, Thank you. That is partly what i have been reading. On the other hand i've also read post in which others have said to have done this; the problem is that they never mentioned how they did it. Hopefully one of those will chime in.
  12. Hello, I've spent hours on this forum trying to find the answer to this question. Replaced/disconnected the cd changer in favor of an iPod (just got the new iphone4) but the radio does not appear to recognize the adapter. I know that on the CDR220 you have to enable the aux and i'm guessing the same may apply to the PCM1. I've read the PCM1 manual but there is no mention of this priocess. I know others have done it, but no one seems to mention how they did it. Does anyone know how to enable the external audio option or aux on the pCM1? Thank you.
  13. What you guys need is a BLAU/8-POD2 which i wrote about on another Porsche forum. works great on both my iphone 3G and older ipod photo
