Rapewta
Everything posted by Rapewta
  1. I am going to attempt to replace the window regulators on my 99 996 coupe.I can hear the motor run when I depress the momentary switch, so I am assuming it is just the regulator assembly sans motor. Will know more when I remove the panel.My question is... Are URO regulators good?I found the genuine replacement regulator for approx. $250.00.Another is offered new by URO that is only $110.00, thru AutohausAZ. I realize it is always better to go with OEM but I am one of those "blue collar" guys that snuck in to the Porsche fraternity by picking up the unpopular 996 for a fraction of what they cost new. So, I pretty much can't just get OEM when something that is just as good is offered by another mfg. for less.If you have installed the URO's, let me know how they worked out.Appreciate it.
  2. Today I called around to independants and new car service repair places to get an estimate on a repair that I was thinking might be over my head.The cost for parts and labor was too high for me.So I got on Amazon.com and ordered the Bentley hardcover service manual for our cars.I saw Loren's great review and knew that it is a good investment.Anyway, I think if I use the combination of these DIY's and the Bentley, I will repair the Carrera and save a whole lot of my hard earned money. Off topic... I joined the Salt Flat Racing Association and will be taking the 996 to Bonneville in Sept. with my 86 yr old father to set some speed records. Records within our family anyway.
  3. I had to replace the water pump last year. I didn't do this at the time. I just drained a couple gals from the drain plug. Nice DIY. Will use this tutorial next time around. Thanks.
  4. You are correct in that Rennlist isn't much for the DIY home mechanics. It is a greatsite for P-car owners but this site is the best place for learning how to fix your car.I have saved lots of time and money by being a contributing member, which reminds me...it is time to donate again. Thanks Loren.
  5. Mine started acting up at around 75K. I replaced it with a NAPA water pump that was not suggested. I have 86K now and the pump is hanging in there. Someone on some forum said they took it out through the top. Wrong. Don't try it. Waste of time. You have to remove a couple hoses underneath and drop it down. For a first timer... it is not easy. One 15mm bolt (I think it is 15 mm, maybe smaller) is hard to get to and if you use a torque wrench, which I used, it gets tough. The OEM gasket is not just for the pump alone. Don't get frustrated. Just put the new gasket over the razor thin original gasket and all will be well. Don't forget to use the proper coolant and your coolant light will come on for a while until you burp out all the air and keep adding coolant. Good Luck.
  6. I have a Fluke 87 VOM that will read "series" DC current. I also have an Ideal 61-702 that doesn't. Shop technicians and avid home mechanics more than likely have meters that read DC amps. You are right in that the cheap meters might not have that function. That's all I was saying. If someone is going to go out and buy a meter, check that it will read DC ma's.
  7. Just a friendly word of caution... Most Volt-Ohm meters only provide an AC current reading function. Not DC, which is what you will be monitoring. I just replaced the battery in my 996. The cronic problem I had was that it would take at least three or four tries to crank the engine over. The battery just refused to charge past 52%. Everything worked fine but when the battery was required to turn the engine over (the heaviest current draw by far), it barely succeeded. The alternator was providing good charging voltage, so I just replaced the battery and it has been about a month now and it starts up on the first try every time. Good luck.
  8. Well... I replaced the hinge on the center console today. After reading all that was available, I went with doing it without removing a lot of stuff like the TSB. All done sitting in the back. Not hard to do. You will have to take a hack saw blade and cut off the unbroken hinge collar, then file both spots till they are flat. The U shaped rivet supports take a needle nose plier to put in place. Knock the shaft out from right to left. Vacuum the aluminum curlies out after you do the drilling.
  9. I changed my plugs at 70,000 miles (that is when I did the 60K maintenance). I put in BERU Z129's and they are great plugs. The spark plug has no moving parts so I don't understand the logic behind changing them every four years. It is how many times the plugs have "fired". If your car is in a good state of tune, time means nothing for plugs. It is the amount of miles you put on the car. Of course, that is my unscientific logic. If Porsche says every four years... you can't do no harm replacing them. Mine will get replaced again at 140K.
  10. I can't second guess Porsche engineering. They say Mobil 1 0W-40 and that is all I have used. Changed the oil and filter yesterday. Purolator L25316 filter and I buy the 5.1 quart containers @ 2. They are $40.00 each, so you save a little from buying quarts. Take the old filter and cut in half. Check for any small metal debris. So far, so good. 85,000 miles.
  11. I just ordered the repair kit today. Thank goodness for the DIY tutorials.
  12. I guess I will look into replacing it. Funny tho... the molding acts like it is shrinking. It is pulling out at the corners. I got bigger fish-to-fry now. The drivers' side window regulator went on the fritz yesterday. Sshhhh....what's next?
  13. I have a great 996 C2 coupe. It is getting old and I drive it every day. My problem is that the rubber weather stripping going around the rear window has started to lift on the passernger side. I really don't want any water getting underneath it. I would like to figure out a way to put some form of adheasive in there and apply some weight on it so it will go back flat. I don't know... it looks like some kind of needle syringe with some glue would do the trick. The stripping is in great shape. Any suggestions from past experiences? Thanks in advance.
  14. Like I stated... I didn't have the funds to get a $300.00 OEM so I put in the NAPA one. Now I have the money, so at the first sign of the rebuilt going out, I will install an OEM. However... the rebuilt pump (plastic) is still running smooth and I will just wait until it goes south on me. I kept the original OEM water pump because they offered me $4.00 for the exchange. To bad I couldn't rebuild it myself. Can I?
  15. I am curious to know what the line (graduation) between 180 and 250 is in degrees. My 996 has never gotten to the middle line. I don't think anything to the left of that line would be considered "over heating." Water boils at 212 deg f and under pressure even higher.
  16. My pump started making some noise at 75K. I didn't know where the noise was coming from but new I had a problem. After around one week, I took it to an independant Porsche mechanic and it was dianosed. I replaced the pump myself and it was not an easy job for a first timer. I suggest you go ahead and replace it with the milage you have. Don't wait like I did. If you are so inclined... You can buy a refurbished one at NAPA for one half the price of an OEM pump. I did that after it was suggested that I don't because they don't last. It was about economics. 4K later.... it is still working fine. Don't attempt to remove the pump through the top. It comes out through the bottom. A great video is here on the site for the DIY.
  17. I think if you look at the 60K schedule you might see that spark plugs should be changed. I did mine at 70K and they needed it. If your 996 is running fine with all the required work done as scheduled... then 60,000 miles or more is fine. Remove the exhaust system and have the wheels off. Very easy at that point. Check out the DIY on this web site and it is not a difficult task.
  18. When I replaced the original plugs at 70K miles, I put in BERU Z129's. I did not gap them. I just replaced the tubes and and plugs and after 8k miles the car still performs great. If I go another 50K on this motor, I will replace them with the same.
  19. Good news! Thanks for the information. BTW... the Carrera has now become my daily driver. We gave my daughter the Volvo 850 T5 last month after she destroyed her VW. Probably in March I will pick up another used 850. The dog loves the Volvos and all my band equipment and all the softball equipment. The wife has a nice SUV and I hate using it for hauling all my cruddy stuff, scratching up the interior, etc.
  20. I have no smoke at all, ever coming out of the exhaust. I have no drips on the floor. No oil in the coolant. No oil smell but between 3k and 4k I am adding oil. I dont get it because I don't understand how the engine is dirfferent than all the other cars (V8's) I have owned. I have had many cars that went 5,000 miles between oil changes and never had to add. I know it is normal from the owner's manual but what's going on? I just went and got another quart of oil today because the dipstick went from full to 1/2 in three K. The car is super and I am thinking that it might not be a good thing to keep the oil full on the dipstick. Where is it going? Thanks in advance. Don
  21. My 996 uses around 1 quart per 3,500 miles. The digital dash graph always shows less oil than what is on the dipstick. I use the dipstick for accuracy. Two independant Porsche repair shops in Sacramento that can help are Shatz & Crumb and Frank's Automotive.
  22. I just had a similiar condition and really thought it was an internal knock. It turned out to be a water pump going bad. I drove it for a few days after first noticing the sound. No CEL. Took it to a independant Porsche repair shop for a diagnosis. The mechanic called, told me it was the pump. I drove it home and replaced the pump. The marbles in the dryer and knocking sound went away. I hope your problem is this easy. Good luck.
  23. Loren... thank you for your help. I really needed it. I get confused eaisly. You make repairs not so hard. Thank you. Don Steiner
  24. I am so glad I found this thread. My symptoms would not be solved by just replacing the ignition switch. I have the switch, part # 100 905 0000. Ref. No. 4A0 905 849 B. I am going to purchase the whole cylinder lock assembly and use this DIY tutorial. Great write-up!
  25. Logray... I have the switch. I just can't get the rotary light switch to release. (that tab at six o'clock.) I can replace the $15.00 ignition switch, which I have when I get the left vent removed. I can't do it without removing the vent so I have access. Like I said, Hokey, but for now I know why the wipers, etc. quit working. A weak spring in the assembly I assume. I really need the technicians' shop manual. Are the ones advertised on-line in CD format complete relacements for the manuals? The car is showing it's age and I would like to try to do as much repairs as possible.
