Jez986
About Jez986
Contact Methods
  • Website URL
    http://
    NJ
    2003 996 Coupe
    2005 995 CTT
    2016 981 GT4
    1997 986
    2005 987s
    2012 991 Cab
Jez986's Achievements
  1. Just looked mine up. Details are not accurate. eg - wrong model year of car.
  2. Did you notice a big difference? Do most shops have this equipment?
  3. Did you ever do this? I am really interested in seeing if it can be done for the 955 transmission.
  4. I bought a Techart module last month from Germany for my 05 CTT. It was used and, per the seller, did not require ant PIWIS calibration etc. plug and play. Using the standard ride hight controls, the highest setting is a lot higher than stock, the lowest a lot lower than stock once the module is installed. When the car is locked it automatically drops the car to the lower than stock load level. Not sure of the actual measurements beyond stock offhand. I got the Techart module as it did not require any splicing. I had to wait a while until one came up on eBay for reasonable money.
  5. Need to get mine done in the NNJ area and curious how it worked out for you.
  6. Thanks Loren. Presumably this means a trip to the dealer. Do you know if this is a simple, quick task?
  7. I would like to replace the BOSE/MOST CDR24 in my 987 with a secondhand PCM head unit taken from a 997. The main goal is to use PCM to operate a Dension IPod controller which I have yet to install, but I'd like any other "standard" functionality of PCM to work too. The PCM part number is 997 642 141 02. Is this a straight plug and play swap, or is there programming needed at the dealer? Any guides on what steps are needed? Thanks, Jez
