tom__w
About tom__w
    New Jersey
    Cayenne 2006 S Titanium
tom__w's Achievements
  1. Before posting I searched the forum but was surprised that I didn't find very many posts. I have the pcm 2 audio system. Has anyone replaced the front door Bose speakers with anything other than oem? I have a blown midrange and dred buying a new one from the dealer. What are they anyway? 6.5" @ 2 ohms?
  2. I think I like mine better
  3. I thought because my car was the Titanium edition they might be different. Also, I see that a number of OEM wheels on eBay that are marked slightly differently: 9JX19H2-ET60 Are these the same?
  4. Image attached. My tires are 19 inch (275 / 45 / 19 to be exact). Also, did this come in only one color?
  5. I am looking for the wheel part number for my 2006 Titanium edition. I presume that they are all the same?? Tom
  6. Well ... I just ordered the Sprint Booster. I'll post as soon as I get it installed and let you know how it works for me. :thumbup:
  7. So you spent around $500 for the two?
  8. I did end up going to ROCS for my service work. Rich did a good job. What impressed me so much was that while I was in there a lady came in because the steering was a bit loose on her car. Rich took the time to show her exactly what the problem was, explaining it in a clear and useful way. He definately took the time to make sure she understood exactly what was wrong with the car.
  9. I have a 2006 Titanium Edition in Marine Blue Metallic. I am looking for the color code so that I can have a local paint guy do some touch up work. A little help..... Thanks!
  10. Don, Thanks. This indy is usually pretty good, though a real tire shop near me may do better. I've used a guy in Bellville (R.O.C.S) for my coolant pipe replacement, I think I may try them first for the tire leak. Tom
  11. I have a 06 Titanium S with stock rims and Scorpion tires. I've had the tires for almost two years now, putting 35K miles on them. For the last 6-8 months my front right tire has been slowly loosing air. I fill it up in the summer every 2 weeks or so but I find myself filling it more often in the cold weather (every 3-4 days). My local indy has a dunk tank and says that the rim is bad. I didn't hit anything, it just won't hold the bead seal. He has tried to 'fix' it twice already. Is this common? Any suggestions? Does anyone recommend using the Porsche tire sealer as a long term solution? Thanks!!
  12. Has anyone used ROCS in Bellville NJ? Looking to get my coolant pipes replaced, possibly early next week. They quoted labor (matching another indy I checked) at $820. I am supplying the parts. T
  13. Thanks. I've spent about $2,800 on repairs over the last 6 -8 weeks so I was expecting my problem to be much worse. Turned out to be just a blown cornering bulb on the left side that was preventing either side from working. Fixed today for $12.95 (set of two). Thank goodness for small favors.
