Andrew McD
About Andrew McD
    google
    Porsche Boxster 2.5
Andrew McD's Achievements
  1. I'm hunting the facelifted PSE shown above, does anybody know where I might find one second hand? Thanks, Andrew.
  2. Does anybody know if this back box was sold in the UK, i'm hunting one but can not even find photos of it off a car. Would anybody know where one is lying about??
  3. By any chance do you have any photos of where that is on the box?
  4. Yup, but I don't get the option on the head unit.
  5. Thanks but going by the type of fault, I doubt its a re-coding issue. It flickers and fades in and out. There is nothing regular to it. I'll get a local automotive electrician to have a look and see what he thinks. Getting Becker to even check it is going to cost hundreds, which is far more than i'm willing to pay, when the unit works perfectly in every other respect. One thing, should the CDR23 have GAL? It does not show in my settings.
  6. Tonight I striped the whole unit down and cannot find anything that looks wrong. Whatever it is it's not just one LED as i'd thought as there are three around the button that all act the same. Also it's not effected by movement or bumps (as i'd initially thought). No amount of bumping, wiggling connectors or pressing connections has any effect on the blinking. Do any electronics folk have any idea what could be causing this??? If it is something giving up the ghost, then I wish it would hurry up as i'd be happier with the lights not working at all rather than this. As at night its very annoying in the corner of your eye.
  7. Hi, does anybody have any idea why the power light on my CDR-23 would be blinking as if it has a loose connection?? I've had the head unit out and checked all the external connections, they are all fine. Also i've had the front face off, and the circuit board looks ok. If you clout the underside of the unit it flickers.....???? Am I right in thinking it should be on all the time, even when the radio is turned off? Any ideas???
  8. If this happens to anybody else, the incorrect dial for this hack is; 996 613 127 00
  9. All sorted, it seems there are two different dials. The first one had only have 4 clicks, the second one has a lot more and works fine. :-)
  10. Nope, no adjustment on the relay, or at least the one I need. Local OPC tells me there is a problem with the dial, so i'm waiting on a new one. With no wiring and just using the relay I get about a 30sec gap. Connect in the dial and it drops to 2 seconds.
  11. Hi Loren, Ah, is it this one 257-268carrera-windshield-wiper-relay? If that is the case how do I set the relay? As mine is the 911 one. Thanks, Andrew.
  12. Hi, I've just added the variable intermittent wiper hack. Is the max delay as Tony asked just 2 seconds? As there is very little difference between max and min, or is that normal? Thanks, Andrew.
  13. Hi, any recommendations on where on ebay to get the bolts from? I like the filler cap, would make spending a fortune filling the car a nicer experience. :-)
  14. Does anybody know if you can splice the porsche microphone onto the Parrot kit? Thanks, Andrew.
