nosturbo
    Eden Prairie MN USA
    911TT cab, GS350
  • Future cars
    Lambo Murc
    Dodge Viper
nosturbo's Achievements
  1. where can I buy this sachs clutch Philip?
  2. Can this clutch kit to be used in a 2004 turbo? http://www.suncoastparts.com/product/PK9972GT2RSCC.html?Category_Code=GT2RSENGINEtrans Thanks
  3. thanks!!! what a rip off at $8 a peice!!!! haha
  4. my oil filter doesn't come with a small o-ring for the tube inside the oil filter housing can anyone please tell me where I can buy them?? Thanks Derek
  5. don't worry Hijack, give them maybe at least 2000 miles to break in, but, night and day when compared to PS2s. I really thought there was something wrong with my car at the begining. Good luck to you!!!
  6. Where do you buy the little o ring inside the filter housing?? The new filter doesn't come with the small o ring. Thanks
  7. you didn't mention anything about the spark plugs. How many miles has been since you changed the plugs?? I had similar experince after I reflashed my ECU with Softronic tune. It turned out the be the plugs. Please check out my post I hope it helps :-)
  8. I think it's the Hankook Tires. I am having the same problem after I replaced the tires. Please check out my other post.
  9. what tire pressure are you running? Thanks
  10. Philip, are you having the same tire problem??
  11. Yes, all tires are the same brand new from tire rack. Is your car lowered?? or with different suspension? Did you drive the car with the top up or down?? I have tried 36/44 and 34/42 Thanks again.
  12. I recently purchased a set of Hankook V12s for my 2004 Turbo Cab. The first 500 miles was absolutely horrible!!! The car felt really "floaty" and unstable, when I hit triple digits. However, As I put more miles on it(currently 1000), it feel progressly better. Has anyone have experince with these tires?? I guess, I got what I paid for the were only $600 for the whole set after the rebate.
  13. Is there instructions online for changing the shocks? I am looking to replace my shocks with Pss10. Thanks inadvance. Derek
  14. I was working on my car last night and found traces of oil in one of the intercooler hoses. It was a very light coating. Should I be worry?? The car is a 2004tt 6sp with 27k.
  15. Problem solved!!!! I changed the plugs(NGK Idridium IK22) today and the car runs perfect now. Thanks!!!
