karmax125
    france
    Other
karmax125's Achievements
  1. hello, i have remove and install my new transmission this week , the most difficult is to unscrews the seven transmission bolts... thanks for your advice advice ::))
  2. ok , first step removing the starter :) thanks a lot
  3. how do you remove the six converter fastening screws ,the easiest access ?? thanks
  4. hello, I received my new transmission, someone have the bentley manual, just the chapter on transmission in PDF ? Work shop manual is not explicit for uncoupling.. thanks :) ps : i can buy a PDF
  5. ok thanks, it's a Z F model transmission , default of drive shaft :> PIWIS.
  6. Ok , i try to change it without removing the engine and secure the converter, i don't have a lift or ramp, so a tutorial will be appreciate :), for drain away it's the same process?
  7. OK Thanks, i found the workshop manual 996 ,the engine does not interfere with the upper screws ?
  8. Hello, i want to remove my tiptronic transmission, is there a tutorial ? thanks
  9. This week-end i try to change fluid of my 996 C2 and look this support topic ::) i make some pics if i can :)
  10. ok Loren i understand ..after check my engine serial number M96/0166X15983 , X is the model year since 1999. thanks thanks a lot for this explication, apparently the new engine is in the car since 2001.
  11. Loren ,why do you think that?
  12. ok thanks, but first registration is 05/05/98 and the serial number is inscribed in reverse ? 38155X6610/96M
  13. hello, My engine serial numbers is M96/0166X55183 , can you tell me if it's a rebuilt engine ? thanks jpa
