Bruce2010
Everything posted by Bruce2010
  1. Hello John Thanks for your feedback Now try code 5497 Please let me know how you get on... Your feedback is appreciated regardless Cheers.
  2. I'm not familiar with the Durametric diagnostic tool. But.. can I ask under what conditions you ran the test. Catalytic Converters don't run under optimum efficiency unless they are very hot. Your efficiency test will be a measure of this. Yes it true, that the O2 sensor will become less efficient long before being indicated by the CEL. You may have a better idea as to when it was last changed.
  3. The directional tyres also known as unidirectional tyres give the best preformance in terms of traction, and grip in the one direction only. It is not adviced to put them on the wrong way, as you will seriously lose grip. In the case of a puncture, and you have to use one the wrong way it should be regarded as temporary situation in the same way as a space saver Just keep them balanced and in the correct direction.
  4. HOW WOULD A CRACK IN THE OIL FILLER HOSE CAUSE A P1123 "RUNNING RICH" CONDITION? CUZ I THINK THAT'S WHAT I HAVE!!! One of the common causes of 'running rich' is a faulty oxygen sensor. I had quick look online, and found fault code P1123 gave 'Oxygen Sensor' Don't rush to change it though, before first making sure it is faulty, and not just some dirty connections. However, some vehicle manufacturer's do recommend changing O2 sensors at regular intervals, as the fault generally doesn't show up on the engine management light in the early stages of failing.
  5. Try code 4365 let me know how you get on... Cheers.
  6. Use code 7498 let me know how you get on... your feedback is important. Cheers
  7. My solution is to use concentrated washing up liquid (the stuff you use to do the household dishes, maybe another name in US) I apply it all over the windows inside and out, and just run it along the rubbers. I usually leave it on for an hour, maybe better leaving overnight in the garage. Always worked for me 100%. I'm told it returns moisture to the rubbers, and revitalises. Your rubbers look perfect. With all due respect to previous post regards silicone products. I'd recommend never to use the stuff near a modern car, especially aerosol products, it plays absolute havoc with electrics - like radio switches, alarm micro-switches, central locking switches etc... It also produces a thin layer over paint work, making it a nightmare for any body work repairs.. any body shop repairer will testify to this.
  8. Use code 4623 let me know how you get on...
  9. Sorry, diference of opinion Your original Becker manufacturer's SN code is 3031
  10. Sorry, I'm Bruce - from Scotland Try code 0325 please let me know of your success, your feedback is important. Cheers.
  11. Hey Chris7 Feel your trying to tell me something here? Clarification: c337cc / BE4462 / SN 15063361 = 6765 chris7 / BE4462 / SN X5035356 = 3165
  12. Try code 3165 let me know how you get on.....
  13. Providing you've quoted correct serial number, Try code 6765 Let me know how you get on.....
