Bruce2010
Everything posted by Bruce2010
  1. Try 9609 ...........
  2. @ teeerex .... your code 8789 @ SValdez .... your code 4308
  3. Try 8630 ........... :)
  4. Try 0106 .............
  5. Just one other thought... the radio is allowing you to enter code?, i.e four stars appear like **** and it is not showing 'WAIT" Sometimes radios will 'time lock', in which case you need to leave radio powered on with ignition to 'accessory' position to reset. Failing any of those problems above... definately a job for the radio decoder. Sorry
  6. OK.... firstly the code given is the correct original code for your serial number. You need to check your serial number, from the label attached to the metal casing. I suspect you have provided the correct serial number, and it is probably the case that the radio has been re-coded to another code in the past. The code is stored in eeprom 24c02, and if you have an eeprom programmer to read the memory contents, I can provide a code from this... If you don't have the equipment to read eeproms, then a radio decoder in your area will be able to help you.. Cheers.
  7. I'm confused... Have you tried code 9276 before, and it has not worked?
  8. Try 9276 .............. let us know how you get on :)
  9. Your radio ..is not coded, in that it needs to have a code entered by the user. The radio is IMMO coded and will only work if connected to the original vehicle... :) See FAQ:
  10. Should request the 5-digit code Use 15126 ... :)
  11. Try 1514 ................
  12. Is it possible to get the unlock code for my CDR22 from the serial number or will I have to pay the dealership? .... Try 9859 ............
  13. Try 4876 ...................
  14. >>>>>>>>>> 0324 <<<<<<<<<<
  15. @ NL boxster For CR220 S/N W5010364 Try 0834 ...............
  16. @boxster_nut 4736 is the correct original code for the serial number given. (I've verified this with two separate sources) Sometimes reading serial numbers from radio displays can give wrong numbers, just due to deteriation of the displays... I'd remove the radio, and check the serial number printed on the label, attached to the metal casing.. You've explained that you've entered 12 wrong codes.... Did the radio go into time lock?
  17. Try 4312 ....................
  18. Try 1549 ........
  19. Sorry, only the Porsche dealership can provide codes for the PCM Refer to
  20. Try 9464 ...............
  21. Try 3290 .....
  22. Try 8702 ....................
  23. Hiya
    Very pleased to hear you've managed to get your radio working. And.. well thanks for inviting me on your friends list. I'm from Scotland, across the pond, work in auto electrics - fixing old cars..... very pleased to meet you.
    Cheers.
    Bruce
  24. Try 2301 ........
  25. Try 9058 .....
