mtimmy
Everything posted by mtimmy
  1. yep I am using Hawk.,. guys should stay away from this,... I have a turbo,. I am thinking to go to the Turbo S route or 8 piston brembo route.
  2. almost in an accident today,. going down hill 25 miles per hour., the car just won't stop!....., it rolled for almost half a block before it stops.,.., the pads been on the car for 1000 miles!...
  3. I dontr remember there is a oil pressure gauge
  4. well worth it! I fixed the module myself for 5 dollars in part., it was an easy fix
  5. It is the lowering unit to lower your air suspension,! I was trying to figure out how to set them with the two varaible resistor knob that is on the control unit, however rinspeed is not helpful neither of their dealer
  6. I got the 0.22 OHM fusible resistor from mouser.com I had them special ordered, but it seemed they purchased a LARGE amount after my special order,. and its now listing on their website now the MOFSET I got it from West Florida Electronic
  7. LONG STORY SHORT,,...My entry and drive system went bad one day., after almost a year of testing , replacing the battery, buying the test tool, almost brought a china piwis ,.... and bringing it to dealer and 800 dollars of dealer time., I had it fixed for 5 Dollars in parts. and one hr of soldering at first my kessy do not communicate to the darmatic tool or PIWIS at all, the dealer went ahead try to replace it , with a superseeded module, HOWEVER they wasn't able to program it for unknown reason, there is no module out there that will take my car's pin and complete the marry process because they said all the module has been superceeded. The dealer offer me to replace ALL the module in the car to an updated version for a cheapo $3000 dollars.! OF COURSE I refused,. ...,. I only lost my alarm horn , entry and drive function and its not worth $3000 dollars,. I was investigating myself trying to see what causing the problem, I came in to the touareg forum and found out those guys there have a lot of the problems with their module too. ... I was like ,hum.,,. then go under my dash and found the kessy module that is EXACTLY the same as theirs including the part number (WHICH IS A VW part number stamped on a sticker btw).... there is one guy there that took his module to a local electrician and found he has 2 fried mofset and 6 fried resistors.!!! I was like, fxxx it, why don't I give it a try, at first I couldn't found the 0.22ohm resistors (its was HARD trust me I took almost 2 months looking for them)., so I went ahead replaced the two mofset........... 15 mins and a lot of smoke later....... MAN,,,... the module can communicate with my Durametic tool...! HOWEVER,, all the antennas are reporting short to ground ERROR!!! I tried to clear it but the code come back instantly. then I went on to test the resistor value,... and found all six of the 0.22ohm resistors are SHORT (they are fusible resistor btw)....,,. sooooo I tried my best and finally able to locate those 0.22 ohm resistor .., fast forward 2 months later............ I received those resistors today.............. another 15 mins of smoke and sweat with my resoldering station... I plug the module back... run the scan tool clean the fault codes!!!!................... moment of truth,, I plug my dummy key in to the key cyclinder with the real key in my pocket!!!!!!!!!!!!! turn and the CAR STARTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have successfully fixed a $3000 dollars repair (that don't guarantee will work) with 5 dollars worth of resistors !!!!!! NOTE: IF your kessy don't communicate with the scan tool,. Its the TWO MOFSET that is Fried. if you have all antennas short to ground or not responding its the 6 resistors!
  8. I changed my for 1700 plus labor 300 dollars !. Brought a reman, from sunset porsche ended up porsche sent a brand new one
  9. If you need a transfer case I have one available I switched it a perfectly working transfer case out and later found out its my front running gear that was broken.
  10. Can you tell me more about the ground strap? ., do you mean the battery ground? or just the ground to that part of the system
  11. the switch in my CTT do not pop open the tailgate, !... I had this problem since the truck was new, then I figured. it only unlock the rear switch on the tailgate,,, if a person actually go open the tailgate by pressing it. then it will open..
  12. TRIED Every thing still the same! the dummy key no longer start the car.
  13. 04 CTT, entry and drive suddenly stopped working.,... used the tool to check and its a code 3, no communication with the module, the remote still works button can lock and unlock the car its just holding the handle the door will not lock or unlock or the dummy key no longer start the car What do you guys think?.... LOW battery power that causes all these?..... however I have the car started and used the tool and it still cannot find the module
  14. 04 CTT, entry and drive suddenly stopped working.,... used the tool to check and its a code 3, no communication with the module, the remote still works button can lock and unlock the car its just holding the handle the door will not lock or unlock or the dummy key no longer start the car What do you guys think?.... LOW battery power that causes all these?..... however I have the car started and used the tool and it still cannot find the module
  15. I think I too drained the wrong plug and have driven the car for like 10 miles.,., do you guys think there will be any damage done, and what kind of fluid does it use other than the porsche only fluid. I've heard Amsoil 75w 90 would do and better ? phew :D RFM thanks. if could add you as friend twice i would do that or give you a star of the forum award (With Loren too :)
  16. Did you get the problem fixed? same thing just happened to me,. it only sound loud with load, even small load ., I try to down shift at 65mph to 5 to 4 to 3., its the same sound with same tempo. I even put the car in netual and it making a very small sound., so I assume its not the engine..
  17. I own both, so does that means the 996 filter 99-01 will fit a cayenne?.
  18. I have it and worked great.! .. Ahh, that sounds good enough. I just replaced that verdammten coolant tank on my 2002 and now need to think about getting one of these vacuum filler-uppers. Bill Bill: This tool will be one of the very best presents you could ever buy yourself. It's that good. Don't hesitate to buy it. The fact that it costs one fifth of what Porsche wants for it and that it is the SAME exact tool (without the Porsche sticker) makes it that much sweeter! Regards, Maurice.
  19. I think I saw your Slk the other day on sunset bldv I was in a CTT turbo with 22 inch
