Q-Ship986
Everything posted by Q-Ship986
  1. Emergency trunk release cable? --Brian
  2. I'll bite... What is it? Heat shield? ;) --Brian
  3. When you get it, please post a picture or two.... Thanks, --Brian
  4. I think you may want to have a look here: http://www.renntech.org/forums/index.php?s...ost&p=41611 --Brian
  5. I test drove, back-to-back, a brand new '05 Boxster against a 1,000-mile CPO '03 Boxster S that I ended up buying last summer. Using Porsche-published data, note the differences between these two vehicles: '05 Base 2.7L 0-60 mph in 5.9s 240 hp @ 6400 rpm.......(par) 199 ft lb @ 4700 rpm.....(par) '03 S 3.2L 0-60 mph in 5.4s 258 hp @ 6200 rpm.......( +7.5%) 229 ft lb @ 4600 rpm.....(+15.1%) I bought the '03S for many reasons over the '05 base, but the test drive was one of the biggest. Though, before I went out, the salesperson assured me I would feel no significant difference. He contended that it was on the track where the difference would play out and unless I was dropping the clutch with hard starts, I wouldn't be able to make out the 0.5 second difference between the two. I drove the 2.7L first with an open mind. My route took me down a busy road with stop lights to a highway, on which I did a few mile loop and returned. Then I took the 3.2L on the exact same route. BTW, both cars were manuals (5-speed for the '05 and 6-speed for the '03). The difference of 18 hp and 30 ft lb of torque was not too noticeable in the stop-and-go traffic, where I could barely get to 35-45 mph before the next light. However, making the turn onto the highway on-ramp was different. There, I could press into it from a street-start of about 5-10 mph. The S applied noticeably more pressure to my back than the base. Not tons more, like a TT, but noticeably more--I think just about anybody could have felt it. When you're talking about how much you 'feel,' I think it is the torque you should examine, especially in the real world (i.e. not on the track). The question here, between the 3.2L to the 3.4L is a matter of 15 hp and 15 ft lb, which are +5.4% and +6.4% differences respectively between those engines. Compare those differences to those from my back-to-back driving impression above. I'm not too sure that if you could take what I felt during those test drives, and divide that difference in half, that it would be all that compelling. So, I'm with CharlieG: my guess is that it would be incremental--at best. Questionable whether it would be a big reason to pick an '07S over an '06S, if that's what you're looking at. --Brian
  6. This was the right thing to do. Other than the reasons I gave above, another reason to keep it is that catalysts need the right temperatures to operate as intended. Too much heat, and the cat can burn up. Not enough heat, and it doesn't do it's job. Sometimes a heat shield isn't a shield, it's a blanket to regulate heat loss. This, and the above, general information comes from contact over the years with actual vehicle manufacturers; FWIW, YMMV, and all that. --Brian
  7. I would not remove a heat shield that was protecting the underside of the car or any component, particularly those of rubber or plastic such as a wheel molding, tire, engine mount, control arm bushing, etc. If the shield is protecting the ground, it can be a fire issue (i.e. if you ever park on grass). Catalysts get extremely hot by design (yes, hotter than the inlet/outlet--chemical reaction(s) are occuring within), and shielding is effective at reducing/redirecting the radiation. Don't know about the warranty coverage, but I would think it would be a nominal fee to tack weld it back into place. --Brian
  8. Took me about 14 hours, but I finally get it. Frankly, I just wanted to use 'gizmo' in a sentence--almost drew a yellow box around the screws. The screws are not held on with much torque, so they must be seized. Try to use WD-40, PB Blaster, or another penetrant to loosen. --Brian
  9. Looks the +5mm screws are supposed to be M6x16 p/n 900.269.106.09, quantity = 8. The regular screws, M6x12, are 900.269.047.09. --Brian
  10. What are the gizmos in the little bag? ;) --Brian
  11. The little screws are more for convenience...they hold the spacer to the rotor/hub. They keep the spacer in place when mounting the wheel and when removing the wheel. If you don't use the screws, then the spacer may stick to the back of the wheel or simply fall. If the spacer falls into the wheel, it could scratch or otherwise damage it. The lug bolts hold the wheel, spacer, and rotor firmly to the hub. --Brian
  12. That is not how I read page 7 in either TSB. These pages state: "Wheel mounting must be done using the 5 mm longer wheel bolts of the 911 GT3..." (5/04 4440) and "Wheel mounting must take place with the 5 mm longer wheel bolts of the 911 GT3..." (4/04 4440) It doesn't say anything like "for size wheels that require longer bolts." It doesn't make any sense for the wheel bolts to be different between summer/winter tire use on the same wheels. However, it is perfectly understandable to me that when technical documents are written for technical matters that are among many hundreds of thousands of pages of technical documents, that sometimes an error or omission is made. I think that is the case with the footnoting for that wheel on page 2 of TSB 4/04 4440. This is a car company that shaved fractions of millimeters from their lug bolts to save unsprung weight. If they are recommending a longer bolt in this instance, they mean it. --Brian
  13. I looked at these TSB's: -- 4/04 4440, dated May 25, 2004, Summer Tire and Wheel Summary -- 5/04 4440, dated Sep 14, 2004, Winter Tire, Wheel, & Snow Chain Applications On page 7 of both TSB's, it is pretty clear: When using the 5mm spacers (no matter what wheel), you must use the +5mm GT3 bolts. However, there is a discrepancy in the footnoting, which is apparently fouling the situation here. Note the following: -- The summer tire TSB does not denote use of the +5mm bolt when outlining use of the spacer for the 18" wheels at the bottom of page 2 (see footnotes on page 3). -- The winter tire TSB does denote use of the +5mm bolt for the same wheels on page 3. Considering page 7 of both TSB's, coupled with practical logic, use +5mm bolts with 5mm spacers. --Brian
  14. http://www.renntech.org/forums/index.php?a...mp;showfile=545 --Brian
  15. They are screws to fasten the spacer to the rotor. --Brian
  16. I use a wide screwdriver; insert it under the push pin and then twist the handle. Grab the pin, rotate and pull, rotate and pull. Pull the pin all the way out. --Brian
  17. Could be that control arm was used as a hold-down when the vehicle was transported on a flat-bed wrecker? --Brian
  18. Petroleum-based lubricants applied to most rubbers are the primary thing to avoid. Silicones mixed with petroleum distillates would likely be an issue, too. Pure silicone, depending on the type of silicone, doesn't necessarily damage a given rubber, depending on the type of rubber. An excellent automotive rubber lubricant--i.e. for seals, o-rings, and the like--is one based on DuPont Krytox. --Brian
  19. You don't say how many miles are on your car, how far this trip will take you, or what/when you had for last service. If you have your car serviced at a Porsche dealer, they may have performed the task you are asking about, which they call "Diagnosis [sic] system: read out fault memory." This is part of the maintenance schedule every 15,000 miles (24,000 km). If you drive less than 9,000 mi (15,000 km) per year, Porsche recommends a yearly maintenance, which includes the same "Diagnosis [sic] system: read out fault memory." "Yearly maintenance" also includes checking fluids, tires, driveline, suspension, etc. Basically, they give the car a once-over. Expect about an hour's labor, like US$90, depending on where you are. Seems like good, practical preventative care for longevity of your car and your piece of mind, no matter what or where you drive. --Brian
  20. An update here, with another open letter for input... As far as the CD goes, I tried it in my other two cars, no problem. Just picked up the car from the dealer; they had almost two weeks with it. I didn't get a chance to talk to the tech personnally, but the service manager had been giving me updates all along. They tried the test disc in at least one other car in their shop to verify to themselves that it isn't the disc that 'pops.' They replaced the amp again, but that didn't work (again). They progressively eliminated each speaker as the problem by disconnecting all of them and reconnecting each individually. Apparently, all the speakers make the popping noise to a degree; I think it is worst from the door woofers. They checked my installation of the rear speaker kit. They replaced the CDR-23. They disconnected the CDC-4 and played the disc in the head unit. They somehow tested the MOST cabling. None of these things panned out. They have offered to try another new amp. I am skeptical, since that would be amp #4 (including the original). FWIW, Porsche is on their 4th iteration of this amp; my original was an -00 part number and the latest is -03. From the TSB's, they seem to have amp issues. But, does anyone really think another amp installation is warranted? The dealer (Cascade) has been extremely helpful and diligent. They have been in touch with PCNA for assistance, but, except for trying another amp, they seem to be at the end of their rope. Any thoughts? Thanks, --Brian
  21. Clean discs, not copies. I took it to the dealer for this issue and a couple other minor items. I didn't troubleshoot it much beforehand; that's their job I figured, given my full warranty still in effect. Now, I'll give it some effort. Since I got the car back, I skimmed through a few discs in the changer. Frankly, certain songs on one disc (Killers--Hot Fuss) were the worst offenders. I took that disc out, wiped it off (again), put it back in...same pops in the same places. Took it out, put it in the head unit. Pops in the same places, but a bit less forcefully. Turned down volume, no change in pop intensity. Turned off "loud" feature and dialed bass back from +5 to 0. Now, the pops nearly disappeared; had to really listen, knowing where they were supposed to be, to hear them. Not sure what to attribute any differences in the CD audio from the head unit to the changer. Don't really think it's the CD's, and don't think it's the amp (especially since it's a replacement). Is this a speaker not handling a deep bass signal appropriately? I'll be trying to figure that out over the weekend, but appreciate any more thoughts. --Brian
  22. My '03 986S has an M490 factory system with CDR-23 (MOST), 6x40 amp, and CDC-4 changer. I have dash speakers, door subwoofers, and a rear speaker kit (PNP, self-installed a year ago) in the pizza oven. Recently, I noticed an occasional popping sound from the speakers, particularly during CD play. It's a rather loud pop, like an electrical surge has been sent to the speakers. Can't tell for sure, but it doesn't seem to come from any one speaker more than another. It sounds like this: POP ! (ha-ha) Anyway, I took it in and the dealer verified the issue and ordered a new amp, which was installed just yesterday. I thought the amp replacement made sense since it's what powers the speakers. But, the problem still persists. Before I run it back in to them, has anyone else experienced this issue? Thanks, --Brian
  23. Be careful using these types of sponges; they are abrasive in the sense of light polishing compound or hand glaze. Do not use too aggressively on a painted surface, such as the "soft touch" consoles and door pocket covers and the like; first the dirt will come off, then the paint. --Brian
  24. I believe the OBD system stores "pending" malfunction information. For instance, the system doesn't immediately illuminate your CEL upon immediately detecting every fault. Many faults must repeat themselves, usually within a predetermined interval (i.e. cold starts, drive cycles, etc.). If the fault doesn't repeat within the designated interval(s), the system clears it. --Brian P.S. I don't think they can tell much about the magnitude or frequency of the "pending" fault. They are just stored code(s). To get magnetude or frequency, I think the car needs to be monitored real time, with "actual" values, using a PST2, PIWIS, or Durametric system/tool.
  25. Well, I guess I'd like to see your sticker to fully understand where the confusion originates. This is mine (2003 986S): This sticker lists numerous tire sizes/types, depending on what came as standard equipment (the ZR17 tires), optional equipment (the ZR18 tires, standard on my S), or special equipment (i.e. the 17" and 18" M+S tires). Your sticker may vary, depending on model year among other things. All the road tires listed on that sticker above are to be set to 29 psi (front) and 36 psi (rear) respectively. (The temporary spare is an exception, which is to be set to 60 psi.) This also corresponds to the information provided in my owner's manual. If your sticker looks like mine, is it possible that you are interpreting the table to mean that 29/36 applies only to that very row of tires? In other words, are you looking at it like this?: (Red box added for emphasis.) If that's how you are reading it, I see your confusion. The table above is correctly interpreted by applying the pressures to the other rows of tires as well. Hope that helps. --Brian
