clarus
Everything posted by clarus
  1. I understand that the serpentine belt should be replace every 60K miles. But is there a time limit for low mileage cars? Like do you have to replace it in 10 years if the car is still less than 60K miles?
  2. Yes, I understand double DIN installation info is plenty full. My question was whether a double DIN install could coexist with DSP amp option (i.e. without replacing the DSP AMP). One of the challenge would be to have both the AC panel and the DSP panel on the lower center console. I'm not sure whether that is feasible since my own measurement seem to indicate it's not. Appreciate any suggestion or advice.
  3. I have a 00S with DSP option, everything is stock. I am considering replacing the head unit with a Double DIN Pioneer X920BT. Looking for advise on the following questions: 1) Does it mean that I would have to replace the DSP amp as well? 2) Should the door speakers be wired as subwoofer? The highest crossover frequency allowed by the Pioneer is 125Hz. If not wire as sub, would it be a copy of front channel? 3) Since 6-channel amp are hard to come by in appropriate size, I am considering running a 4-channel for dash and door, and running the rear channel directly off the head unit internal amp. I have not found any spec on the rear speaker to verify if that would be OK. Thanks.
